jdm 1 piece with no bulbs
Old Feb 3, 2006 | 08:22 PM
veganej's Avatar
Default jdm 1 piece with no bulbs
i got a set of jdm housings, but no bulbs or sockets. ive researched a bit on wiring, but what are some good bulbs to use and how hard would it be to make my own socketing and wire it to use highbeams? i am fairly good with wiring but havent tackled this before. anyone done this or have a diagram?
p.s. dont say search, bc i have and most of it is jackasses who cant take off a bumper that want someone to come to their house and do it for them.
Old Feb 3, 2006 | 09:47 PM
hu's Avatar
hu
Default Re: jdm 1 piece with no bulbs (veganstraightedge)
I got h4 hella bulbs from tirerack.com. For the harness, I ordered KYO from racinglab.com.
Old Feb 3, 2006 | 09:53 PM
hu's Avatar
hu
https://honda-tech.com/zerothread?id=1490713
Old Feb 4, 2006 | 12:23 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: (hu)
Old Feb 4, 2006 | 12:38 PM
veganej's Avatar
Default Re: (Chief Brody)
awesome, thanks for the info on where to source the parts. also if the coating is coming off the lens, can you strip it and re clear it?
Old Feb 4, 2006 | 12:42 PM
hp92lude's Avatar
actually, passwordjdm was selling them last time i checked. for fairly cheap. i spent a little chunk of change on those "ricer" adapters mentioned above.
Old Feb 4, 2006 | 12:55 PM
M2B4's Avatar
go to any parts store (autozone) pick up H4 and H1 bulbs get the base connectors and some universal 3 socket headlight harnesses they sell all this. wire em up and ur done.
TIP: the guy above me said dont use the 3rd terminal on your low beams. If you want them to be a lil brighter double ground them; take your "unused 3rd terminal" and wire that into the negative coming from the light it will double ground it and make them a lil brighter. Worked for me
Old Feb 4, 2006 | 05:06 PM
Community Builder
Default Re: (veganstraightedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veganstraightedge &raquo;</TD></TR><TR><TD CLASS="quote">awesome, thanks for the info on where to source the parts. also if the coating is coming off the lens, can you strip it and re clear it?</TD></TR></TABLE>
You sure can. I can't remember the exact procedure, but I think you just wetsand them and then apply some kind of clear coat stuff.
If you search around a bit, you'll find out how to do it.
Old Feb 6, 2006 | 11:42 AM
veganej's Avatar
thanks, i'll do some research on it. its nothing urgent. i plan to do a write up on wiring this ****. ive seen write ups but no step by step pics. maybe even make conversion harnesses that are plug and play for people who dont want to go through this. the only pain in the *** is the cost of the parts and finding them at stores. ill hopefully finish it up this week i had to dissassemble them bc of condensation now i just need to get all the wiring done and get bulbs.
blk_eg4
Jun 20, 2007 12:01 AM
beaneg6
Nov 7, 2005 12:29 PM
philipwight
12
Aug 27, 2003 04:03 PM
ghettocrxsi
Aug 22, 2003 12:05 PM
98DC2-ITR
Jul 11, 2002 02:46 PM
