Whats is default compression for H22a engine?
Old Feb 3, 2006 | 11:34 AM
GR's Avatar
GR
Default Whats is default compression for H22a engine?
is it normal 15.0 in all cilinders or is it too high?
thkx for your answers
Old Feb 3, 2006 | 12:17 PM
pentaq's Avatar
Default Re: Whats is default compression for H22a engine? (Grobas)
It's kinda high... Should be 9.5-13
Old Feb 3, 2006 | 12:23 PM
98vtec's Avatar
moderator emeritus
Default Re: Whats is default compression for H22a engine? (pentaq)
what unit of measurement are you using?
Old Feb 3, 2006 | 01:08 PM
pentaq's Avatar
Default Re: Whats is default compression for H22a engine? (98vtec)
It's kg/cm2... 15 makes 220psi
Old Feb 6, 2006 | 07:42 PM
Layziejoe775's Avatar
what if compression psi is at 190 175 190 175....bad huh?
Old Feb 6, 2006 | 07:48 PM
SteveoBA8's Avatar
Default Re: Whats is default compression for H22a engine? (Layziejoe775)
maximum variation between cyl's is 29psi according to my fsm and for a usdm h22 normal is 178psi (12.5 kg/cm).
Should be no less than 135psi.
Do a leakdown test.
Old Feb 8, 2006 | 08:39 PM
ludedimage's Avatar
Mine is JDM and has 240 across board
Sproket
May 22, 2006 08:15 PM
superturboprelude
May 22, 2004 01:57 AM
CRXNuts
Apr 17, 2004 05:56 AM
chinhead1228
Jun 17, 2003 05:51 PM
H22ACiViC
Mar 9, 2002 03:05 PM
