LS Parts on GSR HEAD?
Old Feb 3, 2006 | 09:32 AM
drunkenxtiger's Avatar
Default LS Parts on GSR HEAD?
I have a stock 94 LS Integra right now with a turbo kit on it. I want to run 15+psi so I am planning on getting pistons/rods, and arp headstuds. In 2-3 months though, I plan on getting a VTEC Head on my LS block. Will I still be able to use the same pistons/rods and headstuds with the VTEC head on there or will I have to buy a different pistons/rods/headstuds?
Old Feb 3, 2006 | 09:37 AM
splitime's Avatar
Default Re: LS Parts on GSR HEAD? (drunkenxtiger)
Piston/rods will be fine... note though that the compression will vary between the LS head/B16/R head and a GSR head... so maybe run some numbers and plan ahead if you definitly plan to go vtec.
Also... headstuds are different... i think... i'll brb after I confirm this
edit: http://shopping.lightningmotor...t=227 has different listings for different projects... beyond that I'm not personally experience with it.
Old Feb 3, 2006 | 02:48 PM
anybody else have any knowledge?
Old Feb 3, 2006 | 04:55 PM
non-VTEC's Avatar
you can keep the pistons and rods........but you will need to replace the headstuds......
the LS studs are diffrent for a VTEC head. you need GSR headstuds with a VTEC head.
Old Feb 4, 2006 | 01:41 PM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunkenxtiger &raquo;</TD></TR><TR><TD CLASS="quote">anybody else have any knowledge?</TD></TR></TABLE>
It wouldn't kill you do do some of your own research
LS/VtecCrew1
Mar 29, 2009 12:27 PM
Boner_Ben
Jan 28, 2007 06:25 PM
x91crxsix
Jun 29, 2006 08:09 PM
jaydmcrx
Dec 29, 2003 10:18 AM
sadcivic
Sep 25, 2003 08:00 AM
