In the market for a used car. Any issues with DA I should look for?
Old Feb 3, 2006 | 05:46 AM
k-series's Avatar
Default In the market for a used car. Any issues with DA I should look for?
When I'm out looking at cars, are there any problem areas I should look into? I'm in south FL so rust isn't normally a huge problem, but if there are some known things to look out for, I'd appreciate the heads up as well as what I need to do fix it or if should just stay away.
Thanks!
Steve
Old Feb 3, 2006 | 06:03 AM
Backk InTheDA's Avatar
I hate everything
Default Re: In the market for a used car. Any issues with DA I should look for? (k-series)
Im in the market for another DA as well. In terms of what you should look for. Just make sure all major maintenance has been preformed within the last 15k, timing belt, water pump, clutch etc.
In terms of other issues, maybe the notorious leaky passenger floor. Faulty main relay.
Other than this, all I would look for would be a car w/ good maintenance history.
Old Feb 4, 2006 | 09:00 AM
k-series's Avatar
Default Re: In the market for a used car. Any issues with DA I should look for? (BuilttB18C5)
Ok, found one that I'm going to be making an offer on. The car is in great physical shape inside and out but has a bad idle sensor (or something to that effect...that's what the owner said anyway).
Tried to search for it, but his termanology might be off. It causes sputtering once in a while and stalls once in a blue.
Any ideas what he's talking about?
Thanks,
Steve
Old Feb 4, 2006 | 04:01 PM
Sam92Teg's Avatar
Idle Air Control Valve IACV, or maybe the O2 Sensor.
Old Feb 4, 2006 | 04:13 PM
DA jeshy's Avatar
love my da never had any problems with it runs like a dream
Old Feb 4, 2006 | 04:16 PM
DA jeshy's Avatar
Default Re: In the market for a used car. Any issues with DA I should look for? (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Idle Air Control Valve IACV, or maybe the O2 Sensor.</TD></TR></TABLE>
my buddy had the same problem and it was the O2 sencor.
Old Feb 10, 2006 | 04:15 AM
k-series's Avatar
Default Re: In the market for a used car. Any issues with DA I should look for? (DA jeshy)
Yeah, but a bad O2 would throw a CEL wouldn't it?
Well, I'm buying it. Having it picked up tomorrow (I love AAA) and will be fixing those minor things.
Also, where's a good online source for OEM/Aftermarket Acura parts? Some of the OEM ones are just insanely priced.
Steve
CTREM1
Acura TSX
15
Aug 26, 2015 02:23 PM
khiz
Mar 25, 2008 10:18 AM
2.vent0
May 13, 2006 09:03 PM
alias 33
Mar 7, 2004 06:34 PM
