b18 turbo w/ stock injectors
Old Feb 2, 2006 | 07:25 PM
idewson's Avatar
Default b18 turbo w/ stock injectors
can you run a t04e 57 trim with stock injectors on 5-10 psi?
lets say there is a moderate goal of 250 whp...what size injectors would you recommend and how much would stock injectors hurt those power goals?
Modified by idewson at 5:28 AM 2/3/2006
Old Feb 3, 2006 | 07:33 AM
idewson's Avatar
Default Re: b18 turbo w/ stock injectors (idewson)
ANYBODY??
Old Feb 3, 2006 | 08:11 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idewson &raquo;</TD></TR><TR><TD CLASS="quote">can you run a t04e 57 trim with stock injectors on 5-10 psi?
Modified by idewson at 5:28 AM 2/3/2006</TD></TR></TABLE>
Assuming you're not running any kind of manifold pressure based fuel riser i.e. FMU, you won't be getting anywhere past 190-ish on stock injectors at 45-50psi at the rail.
integraRS-T
Jun 26, 2007 05:37 PM
LILSOWEK
Oct 18, 2006 04:08 PM
vteczone
Nov 29, 2004 05:23 AM
Octoman
Jun 19, 2004 10:36 PM
