Car wont start after oil change
Old Feb 2, 2006 | 06:46 PM
Luchini's Avatar
Default Car wont start after oil change
My car wont start. When you turn it on it bogs for about 3 or 4 seconds and then shuts off. It used to start off perfectly on any other Honda. The only thing we did is change the oil and take off the valve cover. Its full of oil now and we put all the spark plug wires back in the right order. I think I might be out of fuel but the needle isnt touching the E yet.
Edit refueled it with gas. Samething. Car bogs for a few seconds then dies. Gonna take off the valvecover again and see if we moved anything by accident.
Modified by Luchini at 4:05 AM 2/3/2006
Old Feb 2, 2006 | 07:16 PM
DAcraze's Avatar
Default Re: Car wont start after oil change (Luchini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luchini &raquo;</TD></TR><TR><TD CLASS="quote">My car wont start. When you turn it on it bogs for about 3 or 4 seconds and then shuts off. It used to start off perfectly on any other Honda. The only thing we did is change the oil and take off the valve cover. Its full of oil now and we put all the spark plug wires back in the right order. I think I might be out of fuel but the needle isnt touching the E yet.
Modified by Luchini at 4:05 AM 2/3/2006</TD></TR></TABLE>
how much oil did u put in the car?
Old Feb 2, 2006 | 07:18 PM
reno96teg's Avatar
Default Re: Car wont start after oil change (DAcraze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAcraze &raquo;</TD></TR><TR><TD CLASS="quote">how much oil did u put in the car?</TD></TR></TABLE>
and why did you pull the valve cover?
Old Feb 2, 2006 | 07:58 PM
t_c_l_6's Avatar
Default Re: Car wont start after oil change (reno96teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reno96teg &raquo;</TD></TR><TR><TD CLASS="quote">
and why did you pull the valve cover?</TD></TR></TABLE>
must not have wanted to use a funnel???
Old Feb 2, 2006 | 08:00 PM
InfamousDC2FI's Avatar
Default Re: Car wont start after oil change (t_c_l_6)
lol
Old Feb 2, 2006 | 08:10 PM
AllMotorDan's Avatar
you guys must have done something wrong or not put something back that you should have. cars just do not start up after oil changes
Old Feb 2, 2006 | 08:14 PM
Uncle Willie's Avatar
Default Re: Car wont start after oil change (biada2.9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biada2.9 &raquo;</TD></TR><TR><TD CLASS="quote">a couple of bottle caps, a screwdriver and 17mm socket fell into the engine when u took the cover off. </TD></TR></TABLE>
Dont forget the Junior Mints either.
Old Feb 2, 2006 | 08:19 PM
integra95gsr's Avatar
are you sure the oil flter is on..lol
Old Feb 2, 2006 | 08:20 PM
ZipTieGUy's Avatar
dont tell me you filled the oil all the way to the top.....
Old Feb 2, 2006 | 08:29 PM
Haleiwa-Brando's Avatar
Bro! I posted ten different posts in your thread last night...step by step explaining how to change your oil. What did you do that you weren't supposed to? You removed the valve cover.....and why did you do it?
Please explain the best you can in the fullest detail possible on what you did removing the valve cover, and puting it back on. This would involve removing the spark plug wires, spark plugs....then in reverse order.
SiR AuToBoT's Avatar
Default Re: (integra95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr &raquo;</TD></TR><TR><TD CLASS="quote">are you sure the oil flter is on..lol</TD></TR></TABLE>
you guys are too funny.
what oil did you use?
corn or vegetable? lol.....
Old Feb 2, 2006 | 08:52 PM
ProjectLSVTEG's Avatar
Default Re: (SiR AuToBoT)
This is the SINGLE MOST RETARDED POST EVER
How the hell did u manage that? You get the mechanic of the day award....
Old Feb 2, 2006 | 08:54 PM
Default Re: (ProjectLSVTEG)
oh, and grab one of these the next time u r at barnes and noble
Old Feb 2, 2006 | 09:04 PM
Luchini's Avatar
Well I pulled the valve cover cuz we were gonna do a valve adjustment but then we found a local shop with a good rep that would do it for $75 and I dont wanna risk messing up the adjustment so we put it back on.
I did the oil change right. Used a funnel, 4.25 quarts, new filter, etc. I finally got it to start. After we put more fuel in it it kept dying but then we revved it up a little bit around 2000-3000 RPM and it finally didnt bog down and die.
I think the car was just almost plain out of gas which is weird cuz the gauge was low but the needle wasnt touching the E nor did the low fuel light come on. Checked the spark plugs and plug wires and they are all good and in the right place.
oh yea some of you guys were a real help
Old Feb 2, 2006 | 09:05 PM
DA jeshy's Avatar
Default Re: (Luchini)
happy that everything worked out.
Old Feb 2, 2006 | 09:06 PM
Luchini's Avatar
Default Re: (jeshy)
Props to Haleiwa-Brando for the help.
I thought when I pulled the valve cover off to do a valve adjustment I moved something or didnt put the plug wires back in the right order I didnt actually take it off to put oil in there.
Old Feb 2, 2006 | 09:07 PM
The spark plugs are properly gapped? You installed all the wires back on properly? When putting on the valve cover no foreign objects got in there? The gasket for the valve cover is making a proper seal?
When you were looking at the gas gauge was the car on an incline?
Old Feb 2, 2006 | 09:09 PM
Luchini's Avatar
Default Re: (Haleiwa-Brando)
Its not really on an incline but its enough when you take the ebrake off the car will roll down.
Old Feb 2, 2006 | 09:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luchini &raquo;</TD></TR><TR><TD CLASS="quote">Its not really on an incline but its enough when you take the ebrake off the car will roll down.</TD></TR></TABLE>
That could have given you a false reading. Integra fuel gauges are a little tempermental like that.
Glad you got it sorted. I was concerned things went south real quick.
Old Feb 2, 2006 | 09:15 PM
Luchini's Avatar
Yea cool thanks I was freaking out to cuz the car started fine before that. The oil change went ok so I figured we must have fucked up somewhere when we took the valve cover so we went back and checked that **** like 5 times lol.
Always check the easy **** first I guess.
Old Feb 3, 2006 | 04:45 AM
B SERIES US's Avatar
the same thing happen to me bout 6months ago,changed my oil car wouldnt start,the dam igniter went bad..crazy shyt..
Old Feb 3, 2006 | 08:37 AM
teg luver17's Avatar
its something with the valves go have them tuned.
Old Feb 3, 2006 | 09:43 AM
Sic_DA_Nine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luchini &raquo;</TD></TR><TR><TD CLASS="quote">Well I pulled the valve cover cuz we were gonna do a valve adjustment
just tell me you put new gasket on when you took off the valve cover
Old Feb 3, 2006 | 09:45 AM
ZipTieGUy's Avatar
check you rfuel pump. it might be going out
Old Feb 3, 2006 | 10:04 AM
daoshao's Avatar
Default Re: (ZipTieGuy)
im thinking you probably knocked something loose...don't know without visually seeing what you did.
kodyhalkyard
26
Oct 26, 2011 06:51 PM
rajayc
22
Dec 23, 2005 05:51 PM
HateV8s
26
Jan 17, 2005 02:14 PM
wup69
Sep 22, 2004 03:51 PM
luv2cruz
Sep 13, 2004 05:33 AM
