car wont start
car wont start
i was drivin on christmas and i was in 3rd doin bout 30 and then my car jus shut off on me at first i thought my knee slipped and turnded tha ignition off but when i went to start it it didnt want to turn over
so tha next day i got a new dissy rotor,cap,spark plug wires and bosch plus 4's and it still didnt start then after that i got a new dissy and it still didnt start
so can anyone plz help me
i also heard that if u take off tha valve cover and try to start ur car and if oil shoot out then ur timin is okay but no oil shoot out then ur timing is wrong and no oil shot out
Re: car wont start (HateV8s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HateV8s »</TD></TR><TR><TD CLASS="quote">i also heard that if u take off tha valve cover and try to start ur car and if oil shoot out then ur timin is okay but no oil shoot out then ur timing is wrong and no oil shot out</TD></TR></TABLE>
Definitely not true.
Check for spark. If there is spark, then get some starter fluid and attempt to start the car while spraying just a mist of starter fluid. If it runs, it's probably the fuel pump.
where can i get starter fluid from and will i have to pull tha gas tank out if it is my fuel pump
also i did buy a new fuel filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HateV8s »</TD></TR><TR><TD CLASS="quote">where can i get starter fluid from and will i have to pull tha gas tank out if it is my fuel pump
also i did buy a new fuel filter</TD></TR></TABLE>
You won't have to drop the tank to change out the fuel pump, just remove the rear seat bottom and the plate that's under it.
When you got a new dizzy, did you use the same ignition coil and ICM?
Moderator
Re: car wont start (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">
?</TD></TR></TABLE>
that is not true.....do you know what kind of car he has?? if he has an ef then he'll be dropping his fuel tank
?</TD></TR></TABLE>
Re: car wont start (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">that is not true.....do you know what kind of car he has?? if he has an ef then he'll be dropping his fuel tank</TD></TR></TABLE>
considering this is the EG+ forum i dobut its a EF bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HateV8s »</TD></TR><TR><TD CLASS="quote">i got a new dissy rotor,cap,spark plug wires and bosch plus 4's </TD></TR></TABLE>
Why bosch? Hondas should only use ngks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HateV8s »</TD></TR><TR><TD CLASS="quote">so how is eg fuel pumps runnin about</TD></TR></TABLE>
what the **** did you say?
Re: car wont start (Spoolin93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolin93si »</TD></TR><TR><TD CLASS="quote">
Why bosch? Hondas should only use ngks.</TD></TR></TABLE>
Why, as long as he's not running too hot of a plug or too cold of a plug he'll be fine.
Re: car wont start (B30M87A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B30M87A »</TD></TR><TR><TD CLASS="quote">Why, as long as he's not running too hot of a plug or too cold of a plug he'll be fine.</TD></TR></TABLE>
True, i personally feel more comfortable running ngks.
True, i personally feel more comfortable running ngks.</TD></TR></TABLE>
Have you found a difference between the two plugs? Cause I run Bosch and I have never had a problem.
As a matter of fact yes i have. I have a few pics of a bosch plug that "exploded" on me. I'll post them as soon as i can find them.
i have fuel my battery is too weak to tell if i got spark cuz when i tried to start it it made a clickin noise from tha started
Moderator
then that is WHY YOUR CAR WON"t start....DING DING DING....we have a winner........
wow...alll this and it is your own stupidity!
