Mini me tonight
Old Feb 2, 2006 | 03:11 PM
suckawillis's Avatar
Default Mini me tonight
SO I am going to do my mini me setup tonight. Should be cake. The question I have is, on my Y7 block, do I need to remove anything from the block for oil gallery? Example:Bolting it all up and going wouldnt seem right, because the feed for oil pressure for vtec comes from real line in block, looks plugged. Should I take that out?
Old Feb 2, 2006 | 03:14 PM
perlmeister8's Avatar
Default Re: Mini me tonight (suckawillis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis &raquo;</TD></TR><TR><TD CLASS="quote">SO I am going to do my mini me setup tonight. Should be cake. The question I have is, on my Y7 block, do I need to remove anything from the block for oil gallery? Example:Bolting it all up and going wouldnt seem right, because the feed for oil pressure for vtec comes from real line in block, looks plugged. Should I take that out?</TD></TR></TABLE>
There is no oil jet in y7 blocks only a6/b7 blocks.
Write up:
https://honda-tech.com/zerothread?id=735196
Old Feb 2, 2006 | 03:17 PM
Default Re: Mini me tonight (perlmeister8)
thanks bro. I've never had anything sohc and used it, always had b motors. I appreciate the help. Also, i know obd2 y8's have knock sensor, does the y7?
Old Feb 2, 2006 | 03:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis &raquo;</TD></TR><TR><TD CLASS="quote">thanks bro. I've never had anything sohc and used it, always had b motors. I appreciate the help. Also, i know obd2 y8's have knock sensor, does the y7?</TD></TR></TABLE>
Yes obd2 y8 have knock sensors, y7's do not. If you plan on running obd1 then it doesnt matter. But if you plan on running obd2 vtec ecu, then you need to get and wire in a knock sensor to keep from getting a cel.
Old Feb 2, 2006 | 03:30 PM
I have a knock, just thread it in? is the location ready? I've never added one before. Wiring is easy, i have that covered. I know its above oil dummy light switch on back of block.
Old Feb 2, 2006 | 03:32 PM
littlej72's Avatar
I put a z6 head on my stock dx (95) bottom end should I have done anything with oil jets? i dont think so.
Old Feb 2, 2006 | 03:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis &raquo;</TD></TR><TR><TD CLASS="quote">I have a knock, just thread it in? is the location ready? I've never added one before. Wiring is easy, i have that covered. I know its above oil dummy light switch on back of block.</TD></TR></TABLE>
Yes it is ready just to thread in. Knock sensor is wired to D6 on the ecu
Old Feb 2, 2006 | 03:35 PM
Default Re: Mini me tonight (littlej72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlej72 &raquo;</TD></TR><TR><TD CLASS="quote">I put a z6 head on my stock dx (95) bottom end should I have done anything with oil jets? i dont think so.</TD></TR></TABLE>
Yes, you should have removed the oil jet between cylinders 2 and 3 towards the rear
Old Feb 2, 2006 | 03:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perlmeister8 &raquo;</TD></TR><TR><TD CLASS="quote">Yes it is ready just to thread in. Knock sensor is wired to D6 on the ecu </TD></TR></TABLE>
actually i cheated, i have a ex harness too. and ecu. car is 00cx, 00 ex motor/parts/harness/tranny etc Thanks though!!!
Modified by suckawillis at 12:51 AM 2/3/2006
Old Feb 2, 2006 | 03:41 PM
97spooncivic's Avatar
g/l, pm me if you have any troubles. save the d-series
Old Feb 2, 2006 | 03:42 PM
actually i cheated, i have a ex harness too. and ecu. car is 00cx, 00 ex motor/parts/harness/tranny etc Thanks though!!!</TD></TR></TABLE>
Have fun
Old Feb 2, 2006 | 03:52 PM
thanks man. Appreciate it. Should take like 3 hours including tranny/clutch swap.
Old Feb 4, 2006 | 01:27 PM
littlej72's Avatar
about putting a z6 head on a 95 dx block, what happens if you dont pull the jet? I dont have any check engine light on? I honestly dont remember if I did or didnot......Anyway to check with out pulling the head? like checking oil preassure to the vtec system......hrmn I have every tool known to man for a honda so I can test it . .. i guess.
Old Feb 4, 2006 | 03:28 PM
vtec wont work, not enough oil pressure
Old Feb 4, 2006 | 03:31 PM
young noob's Avatar
Default Re: Mini me tonight (97spooncivic)
would you do a write up on this please, i would appreciate it, i have a y7 with a y8 head in my basement, but im not confident in the swap, all the instructions are always faint and not clear, and i havent seen a y7-y8 write up, thanks man, goodluck, tell me how the car feels after the swap, im curious of how much a difference it will make
Old Feb 4, 2006 | 03:33 PM
.Ry's Avatar
.Ry
geesh thread hijack..how did the mini me go?
Old Feb 4, 2006 | 03:57 PM
littlej72's Avatar
Default Re: Mini me tonight (turner7205)
Shouldn't I have a check engine light then, there are at least two codes maybe three that would occur. Also the car fails emmisions, im trying to track down why.
Old Feb 4, 2006 | 04:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlej72 &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't I have a check engine light then, there are at least two codes maybe three that would occur. Also the car fails emmisions, im trying to track down why. </TD></TR></TABLE>
just start your own thread plz. suckawillis, how did your head swap go?
Mobeious
Dec 29, 2012 02:30 AM
em1 Ziggy
May 12, 2006 11:08 PM
Mr HYDE
Jul 9, 2005 05:04 PM
clemsonhatch
Feb 8, 2005 10:19 AM
12 oz.
Jul 18, 2004 08:23 PM
