Factory Oil Cooler install Coolant hose question??
I went from a gsr engine to a b16a2 engine. i have gsr water tube with 3 ports on it.
far left port is heater core. second is input for oil cooler (which is left port) and the 3rd port is the IACV port.
my question is where does the output of the oil cooler go. on my gsr block it went back into the block. which makes me think that this block does have that port, but its blocked off (see the rust color bolt under the water tube).
What i want to know is, where to run the output of the oil cooler? is that infact the drainage port on the block (rust bolt?) or since i'm not going to be using the heater, should i use the port off the head by dizzy, as the exit?
basicly its the coolant hose maze, i've looked at the acura diagram but it doesn't apply in my instance...
any help is welcomed. I knkow the thermostat big hose goes to the intake manifold. so i'm left with the oil port on the water tube for heater and the head port for the heater hose.
thanks
another pic of rust bolt to see if it is the coolant return port I need:
bluesi2k:
that's basicly my question, i think that bolt is the spot for the plug into the block, but I want to make sure, that its not some other port. although i know its not a catchcan port or anything, so i think the only thing left is it to be the coolant port, I just need clarification. I know the b16a2 is from the 99-00Si, and that they had oil coolers, just want to make sure. As when i got the block from ERL, it was free from plugs & such.
As for the distributor, engine hasn't went in the car, yet, so no clue on how i like it. I bought it used from speeddreamz.com on here and he liked it.
bump for a non- what turbo is best, what oil return line is better thread
i will attach random off topic pictures, as people love pictures and may just answer the question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever »</TD></TR><TR><TD CLASS="quote">
thanks
Whats that between your oil cooler and oil filter?
thanks
</TD></TR></TABLE>Whats that between your oil cooler and oil filter?
that's the golden Eagle sandwich adaptor, that i run my turbo feed & oil pressure feed.
but i'm still wondeirng what the hell that rusted bolt goes to? Is that the drain for the oil cooler? that's all i'm trying to get after is what exactly is that bolt and can it be the oil cooler return hose? if not, i can just use one of the old heater hose ports or something...
i hate coolant hoses....
i hate coolant hoses....</TD></TR></TABLE>
The rusty looking bolt goes in the hole stright across to the left, and where the bolt is now is saposed to be a water tube. the left oil cooler water line then goes to the water tube where the bolt is now. the right oil cooler line goes to the water pipe. Sorry if thats confusing, it's the best way I can think to explain it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">I thing you have to drill the block in order to use gsr cooler.</TD></TR></TABLE>
I was thinking that as well, but from looking at the posted pictures, it appears that where the rusted bolt is, is infact the coolant drain. and as 92cxturbo said, that's where the left oil cooler port goes, while hte right port is the feed port from the water tube.
I thought i was on the right track, but with the money that's in this block, you like to ask.
what's even worse is i had that water tube port, but i left it on my old dead block i sold back to ERL..... now i'm awaiting acura.
jaysalti
Apr 16, 2011 01:16 PM
skunk2finatic
Dec 16, 2004 02:46 PM
SUNBURST
14
Jan 20, 2004 09:53 PM
