check engine light on
Old Feb 2, 2006 | 07:34 AM
nickhans's Avatar
Default check engine light on
i have a 1991 honda accord lx and i was driving down the freeway and all of a sudden the "s" light was blinking and then a couple of minutes later, my check engine light came on. im guessing that it is my VSS becuase my spedometer does not work. i just want o make sure that it might be it or i can just get the codes from it and see what it is. any input would be nice.
Old Feb 2, 2006 | 11:14 AM
amckee's Avatar
Default Re: check engine light on (nickhans)
http://www.c-speedracing.com/faq/06.php
Heres a link. There is also a sticky thread at the top of the civic forum that has this info and all the codes listed. Get your codes and post them.
Old Feb 9, 2006 | 11:20 AM
nickhans's Avatar
Default Re: check engine light on (amckee)
ok it said 17 which is the VSS
Old Feb 9, 2006 | 11:25 AM
nickhans's Avatar
o yes by the way i changed the speed sensor and it still does the samething im getting really mad
Old Feb 9, 2006 | 11:53 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickhans &raquo;</TD></TR><TR><TD CLASS="quote">o yes by the way i changed the speed sensor and it still does the samething im getting really mad</TD></TR></TABLE>
Did you check the connector terminals for corrosion?
Old Feb 14, 2006 | 05:46 AM
nickhans's Avatar
Default Re: check engine light on (Chiovnidca)
ok this is really stupid, i thought i changed the cable but i think i changed something else. it was down by my wheel on my trasmission, and it only had one bolt holding it on, but when i looked on the internet to see what a VSS looked like, and it looked nothing like the thing that i just replaced. i want to know the location of this thing so i can replace it this time. thanks
Old Feb 14, 2006 | 06:27 AM
nickhans's Avatar
i heard that there is a pin in the VSS, and if it breaks it will stop the signal from the speed sensor to the ECU, wow this stuff gets really confusing. o well its my baby
Old Feb 14, 2006 | 10:42 AM
TheOriginalDonDodda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/faq/06.php
Heres a link. There is also a sticky thread at the top of the civic forum that has this info and all the codes listed. Get your codes and post them.</TD></TR></TABLE>
Thanks for the info..
Old Feb 14, 2006 | 01:10 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickhans &raquo;</TD></TR><TR><TD CLASS="quote"> i want to know the location of this thing so i can replace it this time. thanks</TD></TR></TABLE>
It's on the top rear of the trans. Look below the throttle body.
Brian Price
Jun 18, 2019 02:31 AM
1994CivicGS-R
Oct 9, 2005 06:25 PM
Chicano
May 8, 2005 08:43 PM
Frankie324
Jul 14, 2004 07:48 PM
