It wont go into reverse!
Old Feb 1, 2006 | 08:05 PM
vtec25's Avatar
Default It wont go into reverse!
I have a real bad tranny mount could that be the problem or is it the synchro's??? its a B16 tranny
Old Feb 1, 2006 | 08:07 PM
DohcSide's Avatar
Default Re: It wont go into reverse! (vtec25)
Need more details is the shifter really loose when in gears do you have all 5 other gears working besides reverse, etc
Old Feb 1, 2006 | 08:13 PM
Leb_CRX's Avatar
someone correct me if i'm wrong but reverse doesn't have syncros, so I doubt it's that
when's the last time you did fluid change? and try this, throw it in 1st before reverse (*since 1st has syncros*) try it...if it doesn't go in, take your foot off the clutch a bit (t'il it makes contact) then try again...if it goes in, it's normal, all my honda's have done this
Old Feb 1, 2006 | 10:04 PM
97_delsol_Vtec's Avatar
this same problem happened to me when i went to the track...after i was done i couldn't throw it back into reverse...and it was the only gear that i couldn't go in to (b16 tranny) but then the next day i tried it again..still didn't work...so i lay off the clutch and clutched in again...yanked in into reverse...then it broke free...something must be stuck but i don't have that problem anymore..
Old Feb 1, 2006 | 11:53 PM
postman's Avatar
Default Re: It wont go into reverse! (Leb_CRX)
you have a syncro for reverse. reverse runs off of a reverse idler gear. start with the obviouse stuff then if you pull tranny check like the syncro and maybe interlocks and detents
Aventuraa
11
Jul 17, 2009 05:22 PM
jdmomar
11
Apr 2, 2009 06:06 AM
YVERSION
May 3, 2007 01:56 PM
1SlowSi
Nov 11, 2004 01:46 AM
FifthGearOnline
Oct 30, 2002 03:10 PM
