Will a obd2 gsr shortblock work with a obd1 wiring harness?
Old Feb 1, 2006 | 06:57 PM
chrisgottigsr's Avatar
Default Will a obd2 gsr shortblock work with a obd1 wiring harness?
Will a obd2 shortblock work with a obd1 wiring harness? (because of the sensors) Or would obd1 block sensors be needed?
Old Feb 1, 2006 | 07:16 PM
90Integra_Rs's Avatar
Default Re: Will a obd2 gsr shortblock work with a obd1 wiring harness? (chrisgottigsr)
Just switch the sensors out. The plugs will be different.
Old Feb 1, 2006 | 07:46 PM
Default Re: Will a obd2 gsr shortblock work with a obd1 wiring harness? (90Integra_Rs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Integra_Rs &raquo;</TD></TR><TR><TD CLASS="quote">Just switch the sensors out. The plugs will be different. </TD></TR></TABLE>
anybody have any input on this
Old Mar 18, 2006 | 07:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgottigsr &raquo;</TD></TR><TR><TD CLASS="quote">
anybody have any input on this</TD></TR></TABLE>
Old Mar 18, 2006 | 07:18 PM
and vice versa. (obd1 shortblock in a obd2 car)
Old Mar 18, 2006 | 08:57 PM
Ruben19's Avatar
the only sensor that you have to remove.
will be the crankshaft position sensor.
i did a obd1 to obd2 and all the other sensor are the same.
Old Mar 19, 2006 | 03:06 AM
Takumi Fujiwara's Avatar
Default Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">the only sensor that you have to remove.
Ditto, I did the same
Old Mar 19, 2006 | 06:08 AM
Default Re: (Takumi Fujiwara)
remove or replace?
Old Mar 19, 2006 | 10:52 AM
Ruben19's Avatar
remove.
you dont need it
everything else is the same
Old Mar 20, 2006 | 01:31 AM
remove it and sell it. that's what i did.
QBANBOY407
Honda Civic (2001 - 2005)
20
Oct 9, 2007 08:28 PM
Lil Corb
Apr 30, 2005 12:07 PM
BeavisB16
Dec 23, 2004 10:56 AM
firstgenrex
Dec 21, 2003 05:02 PM
hndarcrb18c1
Sep 7, 2003 09:04 PM
