no getting enough fuel or spark??? hrmmmm
Old Feb 1, 2006 | 03:39 PM
swappedcx's Avatar
Default no getting enough fuel or spark??? hrmmmm
still fudgin with this damn JDM b18b swap into a cx chassis (97) both obd2 motors. While im waiting for my obd1 ecu to come from phearable.net, im trying to get it to at least sound good. From near day one it sounded like it has a "miss". I did drive it up the road and it seemes alright. Im ruinning no cat btw right now. Ignition timing is at 16 degrees BTDC, new plugs, wires, cap, rotor, tested coil and its spot on in specs (didnt test ignitor yet). At idle it sounds like it has a "miss" i say miss becasue it sounds like it studders, or pops kinda. My dad came over last week and said its deffinatly not a ignition miss becasue i would feel it driving. He thought it was a injector partially clogged or stuck open and dripping excess fuel, or a intake air leak. SO i got a can of starter fluid and sprayed all over the intake manifold, IACV, map sensor, TB everywhere and no raise in RPM.
Then i swapped the fuel injectors from our civic and it was the same thing still. When the swap started it would pop or do what it does maybe once every 5-10 seconds, now it does it as long as its running, and it does not change (go faster or slower) with the raise in RPM. It sounds the exact same way.
So i have no clue what it is. When the civic motor was in it ran perfect so i doubt its anything like a clogged fuel filter or line. Also im running 93 octane Sunoco gas.
menappi
Jul 7, 2015 05:57 PM
Lan
Jan 2, 2013 06:45 AM
akinas-crx
Engine Management and Tuning
Nov 13, 2011 06:52 PM
Silvertc
Sep 22, 2011 07:34 PM
Mixmasta
20
Dec 22, 2009 02:53 AM
