my car shakes 2000 ls
Old Feb 1, 2006 | 03:18 PM
zeRozeRo L$'s Avatar
Default my car shakes 2000 ls
i just dropped my car would i have to get alignment and when i'm in high speeds and i start to brake my steering wheel shakes
Old Feb 1, 2006 | 03:32 PM
Deluzional's Avatar
Default Re: my car shakes 2000 ls (rubenlopez2003)
it could be a few things, first thing is to have your alignment checked. You didn't tell us too much info or detail so I have to assume a few things. If your car used to shake at high speeds before you dropped it, check your rotors bc it could be warped.
Old Feb 1, 2006 | 03:49 PM
ck123's Avatar
front brake rotors
Old Feb 1, 2006 | 03:50 PM
b20integrapower's Avatar
Default Re: (ck123)
warped rotors...had the same problem...changed my rotors with some new drilled and slotted and my problems went away
Old Feb 1, 2006 | 04:35 PM
Micha's Avatar
FAILWGN
Default Re: (b20integrapower)
Get an alignment, then if the shaking still happens, it is your front brake rotors. Mine shook horribly when I first bought it, changed rotors and I was set.
Old Feb 1, 2006 | 04:59 PM
StatGSR's Avatar
Default Re: (Blu99teg)
if its on braking its the front rotors...
Old Feb 1, 2006 | 05:48 PM
numbnuts22715's Avatar
yep, front rotors, definately.
Old Feb 1, 2006 | 06:11 PM
cougar10ag's Avatar
a stiffer suspension will cause u too feel the road more. some vibration is normal. don't expect it to go completely away. def get the rotors checked
BucCivicSi99
Suspension & Brakes
Mar 26, 2009 11:08 AM
nhlfan
Aug 23, 2005 02:33 AM
NXBen
May 7, 2004 10:38 AM
nikolai.
Nov 23, 2003 05:28 PM
PetroGuyX
Jun 26, 2003 02:10 PM
