HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE
Old Feb 1, 2006 | 12:26 PM
drumminforev's Avatar
Default HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE
The gayest stupidest thing happened.
I was performing a leakdown test and there is an adapter piece that screws in the hose, and that adapter screws in the spark plug whole.
I go to unscrew it all, and the hose unscrews from the adapter and the adapter stays screwed in. WTF
What could get it out???
UPDATE: got it out with 2 screwdrivers. Thanks to all for help.
Modified by drumminforev at 3:59 PM 2/1/2006
Old Feb 1, 2006 | 12:29 PM
OogalyDoogaly's Avatar
Default Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (drumminforev)
Ouch, chopsticks?
Old Feb 1, 2006 | 12:32 PM
Default Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (OogalyDoogaly)
um, seriously
-JSpecEk*9-'s Avatar
needle nose plaiers
Old Feb 1, 2006 | 12:45 PM
Default Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (JDMEK-9)
too fat to clamp the side of the adapter
delusionracer's Avatar
long pair of needle nose pliers should do the trick.
Old Feb 1, 2006 | 01:38 PM
you have a pic. that would probably help so that we can see what is going on
Old Feb 1, 2006 | 01:45 PM
solpower's Avatar
Default Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (delusionracer)
put 5 min epoxy on the hose and screw it in the adaptor.....................wait 5 min.........................unscrew
Old Feb 1, 2006 | 02:17 PM
Default Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (solpower)
thanks for the idea, i knew some kind of bonding agent but wasnt sure what one to get for metal. either way, i managed to get 2 screwdrivers and clamp then around the sides and untwist....it was a bitch
Old Feb 1, 2006 | 02:47 PM
saywhat's Avatar
I was going to suggest removing the valve cover.
Old Feb 1, 2006 | 02:52 PM
D16z6BoostedEK's Avatar
Try putting the long part of the spark plug wire in there and try to turn in iam pretty sure that fitting is only hand tight let me kno if it works!
Old Feb 1, 2006 | 02:56 PM
pip9's Avatar
Default Re: (JDrock86)
lol, i did that before. You really have to make sure that adaptor on there is really tight on the hose. Luckly for me, it was not too tight and i found a socket that fit down the whole to get it out.
Old Feb 1, 2006 | 02:59 PM
Default Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat &raquo;</TD></TR><TR><TD CLASS="quote">I was going to suggest removing the valve cover.</TD></TR></TABLE>
the valve cover was off the whole time. it was deep still
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDrock86 &raquo;</TD></TR><TR><TD CLASS="quote">Try putting the long part of the spark plug wire in there and try to turn in iam pretty sure that fitting is only hand tight let me kno if it works!</TD></TR></TABLE>
i got it out with 2 screw drivers acting as a clamp. thanks for the advice all!
Old Feb 1, 2006 | 03:32 PM
silverwannabeEM1's Avatar
well i know thread is done, but what i did was put sparkplug down into hole, screw it into the adaptor, and unscrew, ruined my sparkplug, but it got it out! put me into a tight spot, i was kicking myself in the a** after that one. lol
triskpin
Aug 13, 2014 05:35 AM
DeviousCTR
Oct 17, 2007 07:54 AM
hmtcrxsir
Oct 16, 2005 05:51 AM
vxnine
Jan 30, 2005 01:46 PM
Seedc2
Aug 20, 2002 05:40 PM
