Just Curious - D15B8 Redline discrepency
Old Feb 1, 2006 | 11:14 AM
Eyal 951's Avatar
Default Just Curious - D15B8 Redline discrepency
My CX motor redlines at about 5500-5700 RPM according to my tach (from an SI)
this site says redline is 6500 RPM http://www.enginereplacement.c...c.htm
So, for the sake of simply figuring it out (the motor is usless above 4500 RPM anyway... actually its uselss period) which redline is correct, and if im 1000 RPM lower, well, why woud that be. To much backpressure in exhaust due to clogged cat? ecu doing something weird? Tach sucks at life? It seems pretty accurate. Idle shows normal idle rpm etc.
Old Feb 1, 2006 | 11:35 AM
drewbie*'s Avatar
Default Re: Just Curious - D15B8 Redline discrepency (Eyal 951)
it should be 6500 and your right the motor is usless
Old Feb 1, 2006 | 01:57 PM
Eyal 951's Avatar
Default Re: Just Curious - D15B8 Redline discrepency (Drew95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew95eg &raquo;</TD></TR><TR><TD CLASS="quote">it should be 6500 and your right the motor is usless</TD></TR></TABLE>
thanks. So anybody know what could be the issue?
BTW, I have a motor being rebuilt (and slightly built) on a stand, no way in hell I could keep this motor.
Old Feb 2, 2006 | 10:20 AM
Eyal 951's Avatar
anyone? I tried yesterday, it wont rev to 6500. its kinda weird, rev limit varies from 5500-5800. I tried "overrevving into 6100 by downshifting to see what happens it was just in rev limit.
Old Dec 24, 2007 | 09:35 PM
JDMflavor_EJ's Avatar
Bringin back a 22month thread since this is the only thread I've found with the same problem as me.
Exact same problem.
250cc_SuperKart
Sep 13, 2015 08:42 AM
Mikey3000
Oct 19, 2006 03:06 AM
dturbo
12
Oct 11, 2005 06:01 PM
mario82686
Apr 14, 2004 03:40 PM
WhOIZiT
Nov 14, 2003 07:22 AM
