88-91 Prelude Booster and MC on 88-91 CRX
I have searched but have not found any concrete information on this topic.
I want to know if the 88-91 Prelude Booster and MC is a direct swap to the 88-91 CRX. Thanks in advance for the help.
the booster will fit and the master cylinder will fit. the only thing you need to do is bend the brake lines just a little bit to get them to line up with the master cylinder. i have both of these on my 89 civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 »</TD></TR><TR><TD CLASS="quote">i would just go with 1991 civic ex MC, it fits without bending ur hard lines, and the booster also fits.</TD></TR></TABLE>
The EX master cylinder bolts right up to any other CRX and Civic booster, so you do not need to change that unless if you have too. Correct, you also do NOT have to bend the lines in anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy »</TD></TR><TR><TD CLASS="quote">is there a difference between a 91 civic ex mc compared to the 2.0 si prelude mc?? well, except for bending one of the lines to make the prelude one fit</TD></TR></TABLE>
Yes, although they are both 15/16'', the mounting locations is different on the prelude MC (where it bolts up to the booster). You will need to use a prelude booster if you use the prelude MC, and can use the stock booster if you use the EX one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy »</TD></TR><TR><TD CLASS="quote">is one better than the other tho? which one would be better for a brake upgrade?</TD></TR></TABLE>
No. I wouldn't mess with the booster, I'd put an EX one on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC »</TD></TR><TR><TD CLASS="quote">not to thread jack but is the da 15/16</TD></TR></TABLE>
the da integra is 15/16, and to put that MC in, it will pretty much be the same as the prelude si mc/booster. Just put in the da booster and MC and you will need to massage the brake lines a little and thats it.
Antinull
20
Jun 14, 2012 06:15 PM
Solomon1468
May 15, 2011 04:23 PM
