Clutch Switch Kill Button for Security
Old Feb 1, 2006 | 08:53 AM
CardDealer's Avatar
Banned
Default Clutch Switch Kill Button for Security
Modified by CardDealer at 3:01 PM 11/16/2006
Old Feb 1, 2006 | 09:03 AM
Luserkid's Avatar
Default Re: Clutch Switch Kill Button for Security (schlit)
It wont do **** when they try to pop your clutch, unlike a fuel pump kill will.
Old Feb 1, 2006 | 10:38 AM
EE_Chris's Avatar
What's wrong with putting it on the fuel pump CONTROL wire? Don't put it on the actual wire that feeds voltage to the pump. Put it on the control line the ECU uses to activate that particular set of contacts in the Main Relay.
Old Feb 1, 2006 | 10:44 AM
cxSHOE's Avatar
unhook your main relay and put it in your pocket... no wiring cutting and small enough that its not a pain to carry it, plus it plugs in and out easily for all the lazy people. you can also rewire the location of the main relay aswell with no cutting involved either.
i suggest more layering aswell.
also make sure:
1. your alarm fuses are wired and located in your engine bay and not under the dash.
2. wrap your main alarm wires ( ignition, negatives, horn, fuse wires etc) in flexible metal. then wrap it black eletrical wire. this causes cuts due to the metal and takes time to remove.
theres more but im lazy today...
Old Feb 2, 2006 | 08:23 AM
CardDealer's Avatar
Banned
Default Re: Clutch Switch Kill Button for Security (EE_Chris)
SoCalCivic498
Audio / Security / Video
Apr 28, 2015 04:57 PM
jc95148
Dec 16, 2012 02:57 PM
justinkay
Feb 22, 2009 04:21 PM
tnaracetuning
Sep 1, 2008 04:27 PM
raphael
Jun 13, 2006 08:42 AM
