thread is not working
Old Jun 11, 2006 | 08:24 PM
raphael's Avatar
Default thread is not working
i cant see the diagram for the fuel pump kill switch can someone e-mail it to me or send me thread from somewhere ?
Old Jun 12, 2006 | 01:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: thread is not working (raphael)
It's an old post, thats why the diagram does not show up any more, I have not seen another one.
There are a few ways to wire a fuel pump kill switch.
What is the MM&Y of the car you want to do it in? 94
Old Jun 13, 2006 | 05:40 AM
raphael's Avatar
honda civic 96
Old Jun 13, 2006 | 08:42 AM
fcm's Avatar
fcm
Old Fart
Default Re: (raphael)
Find the PGM-Main relay, [fuel pump relay] under dash drivers side to the left of fuse box, [should not be hard to find it's the relay that will click on when you turn on the ign. then click off a second or two later] install an on/off switch, [a 1A switch is big enough] on the green/yellow wire going to the PGM Main Relay, [there are two relays inside the PGM-Main Relay] the green/yellow wire is the fuel pump relay control lead from the ECM, it is a low current ground, so it only needs a small switch.
Cut the wire, [green/yellow] and connect the two cut ends to the two terminal of a SPST, [on/off] switch. 94
g2tegsown
Audio / Security / Video
13
Aug 21, 2008 10:30 AM
beastman@
May 17, 2008 01:05 AM
1989CivicSi
Dec 28, 2005 02:04 AM
5lugSlug
Sep 18, 2005 12:25 PM
VTECorona
Aug 27, 2003 05:50 PM
