Need Good Website for Stock Colors for radio
Old Feb 1, 2006 | 06:54 AM
YEABOY's Avatar
Default Need Good Website for Stock Colors for radio
I know this isnt a Honda/Acura but Im trying to install aftermarket Radio on my 91 BMW 735Il, and cant figure out wich wires are for Speakers. I found the power wires for it. and i can make the radio turn on, but cant figure out wich wires are for Speakers. Can some one help me with a good website or some info?
Old Feb 1, 2006 | 09:03 AM
jweller's Avatar
Default Re: Need Good Website for Stock Colors for radio (Integ4Life)
try http://www.installdr.com
Old Feb 1, 2006 | 09:04 AM
B18C_EJ8's Avatar
Pop test your speakers with a battery. Touch one wire to the + side of the battery, then begin touching the remaining wires to the neg side of the battery. When you've found the correct pair of wires, the speaker will pop/crackle (note this does not harm speaker). Repeat with remaining wires.
Probably won't work if your car has a factory amp though...
You could also ask this question on a BMW forum instead of a Honda forum... :shrugs:
Old Feb 1, 2006 | 09:08 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">try http://www.installdr.com </TD></TR></TABLE>
Thought of that, but they don't list colors for BMW.
Old Feb 1, 2006 | 09:17 AM
YEABOY's Avatar
Default Re: (B18C_EJ8)
Do you know where the stock amp would Be on a BMW? The radio turns on but I tried raisin the volume and putting speaker wires together and none make a sound. so im thinking it has a amp some where. DAMN BMW GOTA MAKE THIS COMPLICATED
Old Feb 1, 2006 | 10:11 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">but I tried raisin the volume and putting speaker wires together and none make a sound</TD></TR></TABLE>
First of all, I don't really like raisins. Second, simply touching speaker wires together will not do anything... You need to apply a voltage to the driver to get any results. Use a AA (or 9v) battery and try what I said above.
Again, you might have better luck on a BMW FORUM.
Old Feb 6, 2006 | 02:29 PM
MestizoRacer310's Avatar
Default Re: (Integ4Life)
try http://www.the12volt.com
Old Feb 7, 2006 | 10:39 AM
romoracing's Avatar
Default Re: (aallbbeerrtttttt)
Switched 12V+ Purple
Ground Brown
Illumination n/a
Dimmer n/a
Antenna Rear Window, Diversity
Old Feb 7, 2006 | 08:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">look at the colors of the wires connecting to the speaker, then you just find those wires in the harness again</TD></TR></TABLE>
I've tried that before on a few cars and it didn't work really, sometimes they [maufacturers] change the color before it reaches the radio, I don't know why...
Old Feb 8, 2006 | 12:31 AM
Bone Stock's Avatar
From: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Default Re: (romoracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romoracing &raquo;</TD></TR><TR><TD CLASS="quote">Switched 12V+ Purple
Ground Brown
Illumination n/a
Dimmer n/a
Where did you find those from?
Old Feb 8, 2006 | 07:37 AM
YEABOY's Avatar
Default (Bone Stock)
I found wat the problem was. there were like 16 to 18 wires in the radio harness, and im like whow thats alot. I traced a wire and it went to trunk. I removed the side panel, and tada, there was a freaking stock amp there. So I traced each wire after that and firgure it out, also ther were like 4 wires that went from radio to Stock Cellular phone, DAMN BEAMERS. so after all that tracing, I finally got my radio to work with out eliminating anything. works good. thanks all for helping me.
Old Feb 8, 2006 | 07:38 AM
YEABOY's Avatar
Also if anyone needs help on a beamer like this let me know ill help out in anyway i can
94accordstck
Audio / Security / Video
Feb 16, 2007 05:04 AM
xoutlawz00x
Jun 24, 2005 08:09 AM
jdmcrx1
Oct 14, 2004 10:14 AM
kevinoneill
Feb 19, 2004 07:13 PM
Young_R
Apr 8, 2003 07:43 AM
