New clutch squealing
Old Feb 1, 2006 | 05:57 AM
AFAccord's Avatar
Default New clutch squealing
Friend has an 02 accord 4cyl with a 5-speed. Shop installed a new aftermarket clutch and flywheel for him a couple months ago. Car runs fine, no issues with shifting grinding, or clutch catching. Beginning of this week, it started squealing when he moves from a stop in first gear. Sounds like tires squealing off the line, but lower pitched. Only happens from a stop, and only while the clutch is engaging. Once it is fully engaged and driving, there are no problems. No other sounds from the tranny. Any ideas?
Old Feb 1, 2006 | 04:04 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: New clutch squealing (AFAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord &raquo;</TD></TR><TR><TD CLASS="quote">Shop installed a new aftermarket clutch and flywheel for him a couple months ago.</TD></TR></TABLE>
Problem found. Sounds like cheap parts.
Old Feb 1, 2006 | 04:18 PM
AFAccord's Avatar
Default Re: New clutch squealing (MooGoCow3)
Really think that could be the sole cause of this squealing problem??
Old Feb 1, 2006 | 07:19 PM
P_Adams's Avatar
P.O.S. throw-out bearing...........
P
Old Feb 1, 2006 | 07:40 PM
SteveoBA8's Avatar
Default Re: New clutch squealing (P_Adams)
Yep my act(junk *** SH%t) T.O.B squeaks also, i greased it up too. I shouldve got an oem one Oh well , my flywheel needs turned anyways so looks like i have plans for spring break
Old Feb 1, 2006 | 08:09 PM
P_Adams's Avatar
DuraLast Clutch Kits: brought to you by DeathZone Auto Parts.
The clutch of choice for the professional Go-Kart circuit.
Note to self: next time use OEM (at least the throw-out Bearing)
P
Old Feb 1, 2006 | 08:18 PM
SteveoBA8's Avatar
Im using an act friction disc, oem pp, act tob=where i had a brain failure somehow. Damn kansas summer sun. I will be getting the Exedy oem organic kit hopefully.
midnitesol
Sep 30, 2006 12:18 PM
92LudeSI
Apr 11, 2004 12:29 PM
m0t0rhead
Feb 5, 2004 04:56 PM
JDMTRSPORTS
Jul 23, 2003 04:20 PM
Simple
Jan 17, 2003 06:59 AM
