CEL Help, With Video..
Old Feb 1, 2006 | 01:38 AM
deanh8's Avatar
Default Car died, wont start.. CEL Help, With Video..
The car is a 91 Civic STD Hatchback, stock 1.5 dpfi.
Ok, the car was driving fine just cruising on the freeway at 75mph, and then it starting cutting out like it was out of gas, but it didn't die right away it was like that for a little while, maybe like a 1/4 mile There was a little metal to metal noise, then the CEL came on and it died right away (all with-in like 2 sec) and wouldn't start again
After it was towed to my house I checked the little LED on the ECU and it was flashing 10 short flashes. I was reading the FAQ on here and it say it will only flash fast 9 times, anything over that will be long flashes. So I would think it would be one long flash if it was code 10 (IAT), not 10 short flashes.
This is my first time ever looking at this flashing code thing, I'm used to OBD2 where it tells me whats wrong haha. It almost looks like the first two flashes are longer then the rest, but I have never seen a long blink in my life so I have no Idea what it would look like or how much longer it would actually be.
Here's a video of the blinking:
http://media.putfile.com/CELCode
Sorry If this didn't make sense, I'm falling asleep typing this, its been along day
If anyone can help me out that would be cool. Thanks for your time.
Old Feb 1, 2006 | 05:43 AM
deanh8's Avatar
Default Re: Car died, wont start.. CEL Help, With Video.. (deanh8)
ttt
Old Feb 1, 2006 | 06:27 AM
crx_88_si's Avatar
ok.. when you frist turn the key on it will flash once indicating it is ok. then it will pause for a second and flash the error codes.
none of our USDM/CDN stock civic/crx's had long/short flashes, just flashes. so count em.
if you saw 10 - 1 for the "ok" flash then that would be 9 = Dist is fubared.
edit: video not working for me, just loads up and black screen,.. i think it's firewalled here @ work.. but wetodd works
Old Feb 1, 2006 | 06:31 AM
DustinRose's Avatar
Default Re: (crx_88_si)
the video worked for me
Old Feb 1, 2006 | 06:33 AM
crx_88_si's Avatar
Default Re: (SunsetElixir)
stupid firewalls
Old Feb 1, 2006 | 06:41 AM
boostinaintez's Avatar
Good way to put it
Old Feb 1, 2006 | 07:23 AM
deanh8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">ok.. when you frist turn the key on it will flash once indicating it is ok. then it will pause for a second and flash the error codes.
edit: video not working for me, just loads up and black screen,.. i think it's firewalled here @ work.. but wetodd works </TD></TR></TABLE>
it was 10 flashes over and over.
Old Feb 1, 2006 | 07:48 AM
stockbee's Avatar
thats what I gathered as well.
I would say check out the archives on jdmcivic. but it's been down forever now. there's probably one on here.
Old Feb 1, 2006 | 07:55 AM
deanh8's Avatar
Default Re: (stockbee)
well then all my info is wrong, whats 10 flashes mean? The paper I have says IAT Sensor.
Old Feb 1, 2006 | 01:46 PM
deanh8's Avatar
Default Re: (deanh8)
anyone?
Old Feb 28, 2006 | 04:53 AM
deanh8's Avatar
update..
I replaced the IAT sensor, and doesnt run. Its getting spark and fuel, timing belt looked ok but didnt really check it out, but it looked brand new.
Compression test showed
#1: 30psi
#2: 60psi
#3: 60psi
#4: 120psi.
I guess the motor is shot, I have a b18 sitting here I need to put in asap.
Old Feb 28, 2006 | 05:08 AM
crx_88_si's Avatar
out! thats REALLY bad compression...
you did it cold i'd imagine since it wont start.. but did u hold the throttle wide open?
Old Feb 28, 2006 | 05:29 AM
deanh8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">out! thats REALLY bad compression...
you did it cold i'd imagine since it wont start.. but did u hold the throttle wide open?</TD></TR></TABLE>
No Didn't push the throttle during the compression test. Yes the motor was cold.
patrickstar
Oct 29, 2011 06:18 PM
codybuRr
Apr 3, 2011 10:21 PM
h22bb1
May 22, 2008 09:25 PM
aych2h
Oct 19, 2006 09:01 AM
AnNiMosSiTY
Feb 6, 2003 02:58 PM
