Loose Timing Belt
Old Jan 31, 2006 | 10:54 PM
lude98SH's Avatar
Default Loose Timing Belt
The other day I had the valve cover off and noticed that my timing belt has way too much play. I can almost pull it off the gear if i wanted to. Im guessing bad auto tensioner...? Any other ideas ?
Old Jan 31, 2006 | 11:45 PM
onefastrx7turbo's Avatar
Default Re: Loose Timing Belt (lude98SH)
yep..bad tensioner
Old Feb 1, 2006 | 06:03 AM
ThE PiMpiN Co's Avatar
Default Re: Loose Timing Belt (onefastrx7turbo)
Dont try to drive it, you could mess up the engine baaad...
Old Feb 1, 2006 | 07:32 AM
96darklude's Avatar
Default Re: Loose Timing Belt (aRaBiAn RiCe)
yes i can personally vouch for that one...u def dont wanna drive it...if u can install the manual tensioner yourself then do that...if not have it towed
Old Feb 1, 2006 | 08:08 PM
lude98SH's Avatar
Default Re: Loose Timing Belt (96darklude)
How hard of an install is it ? Will the amount of space to work in be a bitch ?
Old Feb 1, 2006 | 08:37 PM
CGags13's Avatar
i know you have enough in a 4th gen...and anyone correct me if im wrong but i think more room in a 5th gen
Old Feb 2, 2006 | 07:48 AM
98TypeSH's Avatar
Default Re: Loose Timing Belt (CGags13)
Lots of room to work in a 5th gen if you remove the side motor mount completly, and dissconnect the power steering pump, and pull the power steering fluid off its bracket.
I can take pics tonight if you like. Im in the middle of doing this and have done all this stuff already,
There seems to be a epidemic of failing auto tensioners going on.
Old Feb 2, 2006 | 09:37 AM
lude98SH's Avatar
Default Re: Loose Timing Belt (98TypeSH)
Yea that would be a big help. Thanks
Old Feb 2, 2006 | 01:57 PM
uneek4dr's Avatar
i can slide my belt back and forth on my pulley's as well. how do i fix
Old Feb 2, 2006 | 02:18 PM
ChrisRicketts's Avatar
Default Re: (uneek4dr)
here's a link that will show you what you need and how to convert from the auto tensioner to the manual tensioner.....i strongly recommend that you do this, because the auto tensioner sucks horse *****. this writeup is AWESOME!
http://www.superhonda.com/foru...58149
Old Feb 2, 2006 | 09:07 PM
lude98SH's Avatar
Default Re: (ChrisRicketts)
Nice writeup.
batlground1
Oct 16, 2006 02:21 PM
EM2Civic
Feb 4, 2005 04:33 AM
JDM00SI
Oct 29, 2004 03:47 PM
a1320honda
Oct 8, 2004 11:48 PM
mountster27
Apr 15, 2003 04:38 PM
