screwy gauge cluster after swap
Old Jan 31, 2006 | 10:17 PM
court's Avatar
25 Year Member
Default screwy gauge cluster after swap
before I swapped, the guage cluster was fine. after the swap it does wierd stuff.
for example, when I put the blinker(s) on, the opposite blinker flashes( in the cluster)
and the temp gauge goes nuts.
anyone experience this before?
Old Jan 31, 2006 | 10:29 PM
VtecSyndrome's Avatar
Default Re: screwy gauge cluster after swap (court)
Sounds like a ground issue.
Old Jan 31, 2006 | 10:38 PM
court's Avatar
25 Year Member
Default Re: screwy gauge cluster after swap (VtecSyndrome)
thats what I think too... So i went to the engine ground, and scraped the **** out of where it was grounding to. The trans and the battery are grounded at the same spot on the chasis as well. I scraped the **** out of that area as well, to ensure it was getting metal. My concern was that the trans and ground shouldnt be connected at the same spot?
otherwise im stumped
Old Jan 31, 2006 | 10:42 PM
Check your grounds behind ea.headlight, the little boxes held up by a 10mm. I had to scrape those becuase I was having issues like yours and I had painted the engine bay first so that messed up all the grounds. Amazing how crazy your car can act when you have a ground issue
Old Jan 31, 2006 | 11:01 PM
court's Avatar
25 Year Member
Are you speaking about the 10mm bolts that sit to the inside of each headlight?
if we are talking about he same place, thats where I scraped the crap out of it
Old Jan 31, 2006 | 11:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">Are you speaking about the 10mm bolts that sit to the inside of each headlight?
if we are talking about he same place, thats where I scraped the crap out of it</TD></TR></TABLE>
The ones that hold the little boxes to the insdie of the engine bay, they are grounds as well. They almost look like fuse holders.
Old Jan 31, 2006 | 11:04 PM
court's Avatar
25 Year Member
i'll check that out tommorow dude... thanks for the tip!
Old Jan 31, 2006 | 11:07 PM
kevb18crx's Avatar
everytime i used to use the left blinker my tach would jump around, when using the right my speedo would jump around......it was ground issues also....check them out.
Old Jan 31, 2006 | 11:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">i'll check that out tommorow dude... thanks for the tip!</TD></TR></TABLE>
I hope that's it since it's an easy fix!
Old Apr 23, 2006 | 07:21 PM
884door's Avatar
i have the same issue but only with the new cluster. when i used the old cluster everything works fine... it just doesn't fit in the bezal.
I have a 1988 civic std with a 1991 dash conversion with 1988 dash wiring.
I think i have to repin the plugs for the new cluster.
Old Apr 23, 2006 | 09:03 PM
n3h3bkau's Avatar
Default Re: screwy gauge cluster after swap (884door)
Yes you do and its a pain in the ***. Just follow the copper wiring on the back of the cluster and match them up with the correct layout on the new one. I wouldn't follow the color wiring diagram tutorials cause the 88's have multiple red/yellow wires that you may end up getting mixed up if you just disconnect everything and start from scratch.
Old Apr 23, 2006 | 09:42 PM
884door's Avatar
Default Re: screwy gauge cluster after swap (n3h3bkau)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n3h3bkau &raquo;</TD></TR><TR><TD CLASS="quote">Yes you do and its a pain in the ***. Just follow the copper wiring on the back of the cluster and match them up with the correct layout on the new one. I wouldn't follow the color wiring diagram tutorials cause the 88's have multiple red/yellow wires that you may end up getting mixed up if you just disconnect everything and start from scratch.</TD></TR></TABLE>
alright thanks i'm going to have to try it that way. i think i might take them all out and label them as i take them out and then put them in accordingly. any tips on de- pinning easily????
Old Apr 24, 2006 | 06:25 PM
n3h3bkau's Avatar
A small flathead screwdriver worked great for me, I just pushed the tab down and slid out the pin. Piece of cake.
carlmel
Honda Civic (2001 - 2005)
Mar 14, 2022 11:26 AM
noiks08
Jul 15, 2009 07:34 PM
anotherstar_noz
Jun 9, 2008 12:07 PM
hype_R
Apr 8, 2008 05:35 PM
utn
Nov 12, 2007 01:48 PM
