Check ENGINE!
It turns on because the ECU sensed something that is bad for emissions (typically)
Use this procedure to get the code out, then look up in the chart to see what it means. Then come back.
"My CEL is on! Whats wrong with my car?!"
https://honda-tech.com/zerothread?id=978933
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">Check the 02 sensor
Or tighten the gas cap!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
Or tighten the gas cap!</TD></TR></TABLE>
That worked for me. Unhook the battery to reset the system as well.
yup done that before and freaked out...
can he not reset it with the button under the wheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_r_jon »</TD></TR><TR><TD CLASS="quote">
can he not reset it with the button under the wheel?</TD></TR></TABLE>
That button is for the Maint Required Light, not the CEL/MIL.
Located in the fuse box in the engine compartment there is a 7.5 amp radio fuse that is also an ecu back up fuse. Unplug this fuse for 1 minute and viola the check engine light is gone. If the light comes back on than problems are present. Sometimes cars throw what is called a false code and this may be it. After removing the radiop fuse you will need to reprogram your radio stations.
AnAccordIsForever
Nov 22, 2005 03:55 AM
osuperjohno
Jul 28, 2005 08:17 AM
EKB18BPR3
Jun 18, 2005 10:32 AM
