Ground Control Application Question
Old Feb 3, 2006 | 11:01 AM
Danza's Avatar
Default Ground Control Application Question
Hello,
I have a set of Ground Control coilover sleeves for which I am unsure of the exact specification. They are labeled by GC as being for ITR's w/ Bilsteins (as shown below)
Seeing as I do not own an ITR, I was hoping the ITR forum could help me w/ their experience.
1) Do ITR's have bilstein shocks stock (I am under the impression they do)?
2) Are aftermarket bilstein shocks for the ITR externally equivalent to the OEM version?
Thanks for your help guys, I need to get rid of these and need to know this information to answer anyone who asks about their application.
-Ian
Old Feb 3, 2006 | 11:31 AM
Larkin W.'s Avatar
Default Re: Ground Control Application Question (Danza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danza &raquo;</TD></TR><TR><TD CLASS="quote">
No
No, I believe that the tube is much bigger. I'm not 100% sure about this though. Hopefully another will chime in.
3.) I may be interested in these Planning on going Bilstein/GC as this setup should suit my driving best since I daily drive my R and Auto-x.
-Ian
Old Feb 3, 2006 | 11:43 AM
Danza's Avatar
Default Re: Ground Control Application Question (Larkin W.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Larkin W. &raquo;</TD></TR><TR><TD CLASS="quote">
No</TD></TR></TABLE>
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Larkin W. &raquo;</TD></TR><TR><TD CLASS="quote">No, I believe that the tube is much bigger. I'm not 100% sure about this though. Hopefully another will chime in. </TD></TR></TABLE>
The bilsteins are different than oem shocks for other integras. This was sort of dependent on the first.
They are on ebay now for $200 brand new custom rate 350F/400R
Old Feb 3, 2006 | 11:46 AM
jetydosa's Avatar
25 Year Member
Those GCs will only work for ITRs with Bilstein shocks. The sleeve is made to go over the Bilstein shock instead of the stock ITR shocks.
$200 is good deal for sure and those would make good rates for autox/dd.
Old Feb 3, 2006 | 11:49 AM
Danza's Avatar
Default Re: Ground Control Application Question (jetydosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">Those GCs will only work for ITRs with Bilstein shocks. The sleeve is made to go over the Bilstein shock instead of the stock ITR shocks.
Right, that is what I wanted to make sure. I knew they needed bilsteins but I was asked several times if they fit over ITR OEM shocks and I really didn't know if they were different or not.
$200 is a good deal, since I have koni's, I just want them gone
Old Feb 3, 2006 | 11:54 AM
Dave-ROR's Avatar
Bilstein-specific GC's are make to fit over on the bilstein adj mounting ring. Therefore, they will not mount on any other style of shock. They are similar to Koni specific GC's but use a different sleeve, same mounting style.
Old Feb 3, 2006 | 11:55 AM
Danza's Avatar
I DO NOT want to break forum rules, but for those that are interested:
http://cgi.ebay.com/ebaymotors...ZWDVW
If a mod would like me to remove this, please inform me via PM. Thanks.
I'd assume ITR shocks were valved differently to handle the higher rates. Are there any external differences when compared w/ other integra shocks other than the lca mount?
Old Feb 3, 2006 | 12:00 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danza &raquo;</TD></TR><TR><TD CLASS="quote">I'd assume ITR shocks were valved differently to handle the higher rates. Are there any external differences when compared w/ other integra shocks other than the lca mount?</TD></TR></TABLE>
Are you talking about the Bilsteins?
If so, the normal integra bilsteins are HD models, the ITR are Sport models. This may mean different valving, not sure, it does mean that the ITR ones have more height adjustment points on the shock itself (you install a ring in a groove and have a few choices).
I am not sure if the body diameters are different. I've installed a LOT of bilsteins on both non ITRs and ITRs and have never cared enough to measure..
Old Feb 3, 2006 | 12:54 PM
Danza's Avatar
Default Re: Ground Control Application Question (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">
I am not sure if the body diameters are different. I've installed a LOT of bilsteins on both non ITRs and ITRs and have never cared enough to measure..</TD></TR></TABLE>
Alright, thanks a lot
Old Feb 3, 2006 | 06:08 PM
uNF$@#!'s Avatar
They are on ebay now for $200 brand new custom rate 350F/400R </TD></TR></TABLE>
if you trust ebay sellers to give you exact custom rates...sure... do you have a link to one of the auctions? not to mention what length spring they use.
Old Feb 4, 2006 | 05:28 AM
Dave-ROR's Avatar
Default Re: Ground Control Application Question (uNF$@#!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uNF$@#! &raquo;</TD></TR><TR><TD CLASS="quote">
Uhhmm he's the seller.
Old Feb 4, 2006 | 09:45 AM
Danza's Avatar
The link's above, I'm the seller. I KNOW they are the rates said:
OoAoO
May 31, 2008 08:17 PM
Ekfor
Suspension & Brakes
Mar 25, 2008 07:44 PM
tduzzle
Suspension & Brakes
Feb 19, 2008 05:24 PM
tougeDC4
Suspension & Brakes
Dec 29, 2006 10:39 PM
CivicHP
Suspension & Brakes
Sep 27, 2005 10:27 AM
