how to fix my hatch. (1990 CRX)
Old Jan 31, 2006 | 07:54 PM
MrPisto's Avatar
Default how to fix my hatch. (1990 CRX)
i rarley "pop" my hatch from the interior of the car when i need to open it. usually i just unlock it with the key. But i recently did "pop" it using the hatch release lever...anyway, now it wont lock...its like stuck open.
If anyone has had this problem and knows how to fix it without having to find a whole "new" hatch release assembly, then please Post.
Thanks.
Old Jan 31, 2006 | 08:11 PM
ktp1798's Avatar
Try spraying the latch with some lithium gease or even WD 40. Then pull the release **** several times to see if that worked.
Old Jan 31, 2006 | 08:16 PM
jdmcars.com's Avatar
Default Re: how to fix my hatch. (MrPisto)
Did you check to make sure the release **** went back down all the way.
Since you barely use it, sometimes the release **** will stick in the up postition, or just not all the way back down -and it is holding the hatch in "pop" postition.
Just something to double check incase you haven't. Just try to push down the release **** from inside.
Old Feb 1, 2006 | 07:09 PM
MrPisto's Avatar
the release button wasnt stuck up and i tried the screwdriver to get it to close....and it wont click into place.... the spacer trick sounds like a good idea....
and thats real shi**y that someone stole your car bc of that....mine will sit in my buddies garage untill fixed!
Old Feb 1, 2006 | 07:20 PM
Speed--Freak's Avatar
Are you shure the latch is in the open position?
I've seen cars that open and then when you pull the hatch up, the latch falls back to the closed position.
Open your hatch and turn the key to the open position, then while you are doing that grab a screw driver and play with the latch.
See what I'm saying or do I need pictures?
Old Feb 1, 2006 | 07:25 PM
boostinaintez's Avatar
Default Re: (Speed--Freak)
speed freak that is one funny quote
Old Feb 1, 2006 | 08:40 PM
da9wonder's Avatar
blah
Old Feb 1, 2006 | 09:50 PM
Yeah it was funny as helll but I have been reading a few of this guys posts and he knows his ****.
I think that he may be from another country and is typing phoneticaly.
In which case that would make me an ******* for picking on somebody that couldn't help it.
zach1288
Jul 20, 2009 12:28 PM
drmix
Dec 11, 2007 08:05 PM
theemaddhatterr
14
Jun 6, 2004 03:33 PM
RicedREX
13
Jul 4, 2003 01:30 PM
TRE_
Apr 15, 2003 03:54 PM
