START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!!
Old Jan 31, 2006 | 06:20 PM
94eg2sol's Avatar
Default START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!!
Hey how`s it going guys im intrested in installing a button or installing something in my car so no1 can start the car without the trick ( FOR EXAMPLE : HOLD THE HAZARDS BUTTON WHILE TURNING THE KEY TO START IGNITION) i have seeen this done before , I want to install a chrome looking button in my ciggerete lighter hole , i want it so i have to hold down the ciggerte lighter (holding down the ciggerete lighter will press that button and then i have to turn the key to start the car ) so whenever i leave the car somewhre i just leave with my ciggerete lighter , Obviously the cigg lighter wil no longer be functional i want to know how i can get this wired Please help Thank you your advice and help will be greatly appreciated thank you
Old Jan 31, 2006 | 06:30 PM
94eg2sol's Avatar
Default Re: START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!! (94eg2sol)
really intrested in this crime rate in my area is UNBELIEVABLEEEEEEE
94hatchling's Avatar
well... if you arent going to use the cigarette lighter, then i would think to remove the assembly it is attached to, and cut off the back of the lighter housing. make a bracket or make a way to mount the button inside the housing. before mounting permanently, test fit for proper engagement, to make sure it works.
from there, just wire it up like a normal kill switch. either for a starter kill, or for easier, wire it to the ground wire for the clutch. like normal you have to depress the clutch to start this car, this way you have to depress the clutch and press the button to start the car. good luck!
EDIT: wouldnt it be hard to turn the key with your right hand AND push in the cigarette lighter with your right hand at the same time? just a thought.
Old Jan 31, 2006 | 06:39 PM
Top-Fuel's Avatar
this is intense stuff lol interesting though.
I have a kill switch/starter as well but can't find anyone willing enough to do it and plus i'm not experienced at all! lol
94eg2sol's Avatar
Default Re: START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!! (94hatchling)
i have a del sol, cigg lighter is right next to my seat do it wudnt be hard at all , and i dont wanan completely take out the cigg lighter because of the fact i dont want ppl to know about it , the purpse to have it there is so if they brake into my car they dont see a button and be like ( since car isnt starting let me press this and turn key) know what i mean ? and ive never installed a kill switch or what not so im not sure what materials i would need any help ?thanx
Old Jan 31, 2006 | 07:12 PM
94eg2sol's Avatar
bmp?
Old Jan 31, 2006 | 07:16 PM
95-EJ1's Avatar
ohH wow...a DIY on this would b dope. i'm interested as well :D
Old Jan 31, 2006 | 07:18 PM
Sleepy_Red_hatch's Avatar
i dont have a doubt in my mind that someone wanting to steal a car would look in HT first....so everyone knows your trick and it just lost that much effectiveness
Old Jan 31, 2006 | 07:19 PM
95-EJ1's Avatar
Default Re: START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!! (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a doubt in my mind that someone wanting to steal a car would look in HT first....so everyone knows your trick and it just lost that much effectiveness </TD></TR></TABLE>
true. but i won't be post where i will place my button though. just interested on a how to if it's possible
Old Jan 31, 2006 | 07:27 PM
94eg2sol's Avatar
Default Re: START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!! (95-EJ1)
trueeee.... i have many many ideas whre to place it there so many buttons lol i just need some help on what marterials to use ... and how to do it doesnt necesarily need to go there help me out People lol
Old Jan 31, 2006 | 07:31 PM
look in the audio/visual/security forum. i know there is already DIYs available.
and i didnt mean to completely remove the cigarette lighter altogether. you know there is a cylinder right that the light itself pushes into. cut off the back of the cylinder, and mount button there. that way when the lighter is pushed in, it then engages the button.
Old Jan 31, 2006 | 07:33 PM
here, i made it easy. DIY already written and available. its actually stickied on top of the audio/security/video forum. nice and available and easily searched for.
https://honda-tech.com/zerothread?id=1194912
Old Jan 31, 2006 | 07:35 PM
importrule's Avatar
since the coil of the cig lighter is made of conductive material... maybe you can use the coil itself as the switch by relocating the starter wires from the ignition to the cig lighter? so, you'd have to keep the key to on, then push the cig lighter to start the car... just that you'd probably have to pull the cig lighter after the car starts..
Old Jan 31, 2006 | 07:45 PM
TekSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importrule &raquo;</TD></TR><TR><TD CLASS="quote">since the coil of the cig lighter is made of conductive material... maybe you can use the coil itself as the switch by relocating the starter wires from the ignition to the cig lighter? so, you'd have to keep the key to on, then push the cig lighter to start the car... just that you'd probably have to pull the cig lighter after the car starts.. </TD></TR></TABLE>
that depends on the resistance of the coil and how much of the 12volts will get to the signal post on the starter or not. i'm not sure what the resistance is, but i assume it's high so it creates alot of heat. good idea, but you'd have to modify the lighter so the resistance is minimal
Old Jan 31, 2006 | 07:46 PM
Top-Fuel's Avatar
Default Re: START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!! (importrule)
ya that link is pointless now, too old, no pictures available. Keep searching i'm sure there are other DIY...pretty sure i saw one a couple months ago.
what i found so far
http://www.vsracing.net/~suspe....html
http://sonolithics.com/files/bosch.pdf
https://honda-tech.com/zerothread?id=1098293
Old Feb 1, 2006 | 04:51 PM
94eg2sol's Avatar
Default Re: START SWITCH tirck to start ignition HELPPPPPPP !!!!!!!!! (Top-Fuel)
niceeeee
dingobat
Feb 22, 2011 03:32 PM
StreetRiot_DRE
19
Jul 26, 2008 10:25 AM
tampabitches
Aug 14, 2006 02:56 PM
hondapwred95
Sep 2, 2005 03:15 AM
