my gsr burns to much oil ..
Old Jan 31, 2006 | 06:06 PM
dexGSR99's Avatar
Default my gsr burns to much oil ..
i drive my car very hard.. and i was wondering whats the first thing to go for your car to start smoking blue smoke .. i have a 99 GSR.. and its been blowing out blue smoke.. but its only when i get on it hard... i use 10w-30 mobil one syn oil... should i change it? or no.. i just changed to that from 5w-30 mobil 1... what should i do? valve seals or do you think my piston rings are shot??? hellllpp mee!!!
Old Jan 31, 2006 | 06:09 PM
numbnuts22715's Avatar
mobil 1 burns up quite a bit.
but since its blowing out blue smoke somethings wrong.. I dont remember what that is though
Old Jan 31, 2006 | 06:12 PM
PrinceAli132's Avatar
Default Re: (numbnuts22715)
Try doing a leak down test.
Ali
Old Jan 31, 2006 | 06:22 PM
Luchini's Avatar
Default Re: (PrinceAli132)
mine burns a **** load to but i dont have blue smoke. i had to put in 3.5 more quarts for a 3000 mile drive.
Old Jan 31, 2006 | 06:28 PM
dexGSR99's Avatar
Default Re: (Luchini)
everyday i have to top it off... its friggen redicoulos...
Dartanian's Avatar
Default Re: my gsr burns to much oil .. (dexGSR99)
Your piston rings are toast. Valve seals only smoke in high vacuum (which isn't the case when you are at WOT).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luchini &raquo;</TD></TR><TR><TD CLASS="quote">mine burns a **** load to but i dont have blue smoke. i had to put in 3.5 more quarts for a 3000 mile drive.</TD></TR></TABLE>
mine as well.. it doesnt have any colored smoke, and it doesnt leak anywhere from what i can tell, so i have no idea what it is.im not too worried about it though.
Old Jan 31, 2006 | 06:30 PM
dexGSR99's Avatar
Default Re: (dexGSR99)
soo... that sucks..
Old Jan 31, 2006 | 06:33 PM
DarkDragon's Avatar
do a compression and leak down test on your motor. if its smoking in the upper RPMS then its problly gonna be ur rings. Does it smoke on start up at all?? mine does and also smokes high in RPMS, some smoke on start up usally means valve seals
Old Jan 31, 2006 | 06:40 PM
Luchini's Avatar
Default Re: my gsr burns to much oil .. (DarkDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">
mine as well.. it doesnt have any colored smoke, and it doesnt leak anywhere from what i can tell, so i have no idea what it is.im not too worried about it though.</TD></TR></TABLE>
Why not? I am. Almost 4 quarts of oil for a 3k trip is way too much imo. Almost a full oil change. Sometimes I wish I could see some blue smoke or a leak so at least I would have somewhere to start.
Old Jan 31, 2006 | 06:41 PM
pat.ter.rick's Avatar
you should go easy on your car..stop driving it so hard...
Old Jan 31, 2006 | 07:12 PM
jdmdc2110's Avatar
Default Re: my gsr burns to much oil .. (g0t vtec-)
thats the same problem with my gsr. people have told me it blows out a blueish smoke when i get on it and i have to add about a quart a week or more. i havnt gotten a comp. test yet but i heard that will be your best bet on telling where the problem is coming from.
Old Feb 1, 2006 | 12:55 AM
mike2343's Avatar
if u have a intake manifold check thats its setup the right way such as the hoses
Old Feb 1, 2006 | 05:10 AM
maggsgsr's Avatar
Default Re: my gsr burns to much oil .. (mike2343)
My first GSR use to go through about 1 qt every 1k. I thought all GSR's burn a little, until I picked up another. My new GSR doesn't burn any oil whatsoever. Stays on the top line after 3K.
Old Feb 1, 2006 | 06:10 AM
JoePSI's Avatar
Default Re: my gsr burns to much oil .. (maggsgsr)
Mine burns If i get on it alot but i dont have to top it off. I just notice it lower on the dipstick, but not below the fill line. I change my oil around every 2500miles though.
Now that i think of it, I did use full synthetic one time and it burned alot more than usual. I switched back to castrol gtx and its been smooth riding ever since.
Old Feb 1, 2006 | 07:44 AM
THE LORD OF CHAOS's Avatar
my gsr doesnt burn any oil, and i use mobil 1. i changed my oil after ~4k miles and it was still right below the top mark.
Modified by fistandauntilus at 10:03 AM 2/1/2006
Old Feb 1, 2006 | 07:58 AM
redGSRguy's Avatar
Default Re: (fistandauntilus)
Mine was burning a lot of oil due to a burnt exhaust valve. Don't know how that happened though.
Old Feb 6, 2006 | 11:24 AM
JoePSI's Avatar
Default Re: (redGSRguy)
Found my problem while changing my clutch. Mines leaking most not really burning
The owner before me was an older man and took my gsr to the Honda dealership everytime there was any issue and for every oil change.. I have receipts of this.
A honda mechanic must have taken the oil pan off or some reason and when he put it back on he put honda-bond all around the oil pan instead of just the corners like you're supposed to, this caused the oil pan bolts to not be as tight as they could be because of the hondabond. My exhaust gasket, that connects the header to the cat also was blown. it was like caved in, may have caused me to run a litte rich causing the black on my bumper.
Another common leak is around the vtec solenoid where it connects to the head. Mine is slightly leaking from there but nothing to be remotely worried about. I usually only notice a drop come down when i jack up my car.
Modified by _Joe at 12:36 PM 2/6/2006
Old Feb 6, 2006 | 03:49 PM
Sohc Turbo's Avatar
burning blueish smoke is most likely to be ur head gasket leaking cooling to ur oil.. and from smoking when ur drive hard on it.. is more than likely to be ur ring.. cuz it happen to my gsr before....
Old Feb 6, 2006 | 04:00 PM
7mile's Avatar
Default Re: my gsr burns to much oil .. (jdmdc2110)
valve guides? piston rings? leak down test to find results
Old Feb 6, 2006 | 04:27 PM
non-VTEC's Avatar
piston rings.........90% of the time its the rings......very rare is it valve seals when it blows that much smoke and goes through that much oil.....
codyb13
Jun 16, 2005 08:47 AM
ZoominTeg
Apr 10, 2004 02:59 PM
X-cement-filled-EG-X
Apr 5, 2004 04:01 PM
viprcr1
Mar 5, 2004 02:32 PM
Cyber ITR
Jan 7, 2002 05:10 PM
