MAP Sensor Code?Missing Link
Old Jan 31, 2006 | 05:44 PM
bmoser18's Avatar
Default MAP Sensor Code?Missing Link
I have a LS Turbo and I am using a VAFC to tune my fuel. Once I hit 12-13 pounds of boost I throw a MAP Sensor code and my car runs like poopy. As soon as I start it up again it runs fine. I tried using a missing link to avoid the code, but my car didn't run right at all, and as soon as I unhooked the missing link my car ran good again. Any opinions or knowledge of how to rid my code with my VAFC. Thanks
Old Jan 31, 2006 | 06:17 PM
Luserkid's Avatar
Default Re: MAP Sensor Code?Missing Link (bmoser18)
You need to upgrade your map. Stock honda maps are only allowed 11.7 psi.
Old Jan 31, 2006 | 07:11 PM
Emshhh's Avatar
Default Re: MAP Sensor Code?Missing Link (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You need to upgrade your map. Stock honda maps are only allowed 11.7 psi. </TD></TR></TABLE>
exactly what he said
Old Feb 6, 2006 | 08:41 PM
Azndude1983's Avatar
Default Re: MAP Sensor Code?Missing Link (iGfrequency)
you guys said Stock Honda Map is goof up to 11.7PSI? so that means if i'm running between 7-8psi of boost, there's shouldn't be a problem right?
Old Feb 19, 2006 | 05:39 AM
123456civic's Avatar
Default Re: MAP Sensor Code?Missing Link (Azndude1983)
I turbo my d16z6 and it is only boosting 8 and sometime my map sesnor code come up!
2fastek
Oct 1, 2008 10:38 AM
dominate9
Nov 15, 2003 01:01 PM
forced-d16
Sep 22, 2002 11:46 PM
Turbo EG6
Aug 19, 2001 05:04 PM
