fuel problem gas is not going from the fuel pump to a fuel filter
Old Jan 31, 2006 | 04:20 PM
crnimacak's Avatar
Default fuel problem gas is not going from the fuel pump to a fuel filter
hey everybody i need some help.I have a Honda civic 1992 Hatch.I'm having some fuel problems big problems.My car was runing fine and then all the suden it died while i was driving.I checked for the spark and yea there is spark.Then i checked fuel and there was no fuel at all.The car starts maybe 1-10 times,and thats when i can hear a fuel pump working just fine.SO i tho it was a fuel pump so i just changed it and its the same problem.Also i changed fuel relay and no difrence.I need help AASP thnx
Old Jan 31, 2006 | 05:42 PM
Arawn_Wilsawn's Avatar
Default Re: fuel problem gas is not going from the fuel pump to a fuel filter (crnimacak)
did you change the fuel filter it chould be clogged up and check your injector pulse to see if the injectors are getting power
Old Jan 31, 2006 | 06:31 PM
crnimacak's Avatar
Default Re: fuel problem gas is not going from the fuel pump to a fuel filter (Arawn_Wilsawn)
well i dont think its fuel filter why becouse there is no fuel coming to the filter at all maybe 1-10 and thats when i hear the fuel pump working normaly how can it be a fuel filteri unpleged the oil lines the one that conect to a fuel filter and there is no fuel going tro at all ???
Old Apr 21, 2006 | 01:55 AM
em1 Ziggy's Avatar
try checking your fuses
Old Apr 21, 2006 | 07:57 PM
hondastreets1's Avatar
check for clogged or pinched lines
Old Apr 21, 2006 | 10:11 PM
Stripped Honda's Avatar
99-0104
Default Re: fuel problem gas is not going from the fuel pump to a fuel filter (hondastreets1)
try using compressed air in the fuel pipe and if there is somethign stuck in there it should free it
sasinorm01
Mar 19, 2015 09:28 AM
hermtm2
23
Apr 8, 2009 06:17 PM
DevontElan
Feb 14, 2008 03:16 PM
646EG
Jan 16, 2008 09:30 PM
The_In_Kid
May 15, 2002 12:33 PM
