transmission problem..help please
Old Jan 31, 2006 | 02:32 PM
96CivicTN's Avatar
Default transmission problem..help please
ok let me tell you my problem and please try to help me
my shifter has been acting up sometimes the isnt and play in nuetral u know when its in the middle of the shifter you can move it left and right etc.
and 4th gear is like you got to actully put pressure on it when you shift to 4th and 3rd and 2nd grinds sometimes and goin from 4th to 5th i got to put pressure to get it in to the gear. and sometimes i cant even get it into a gear i gotta keep wiggling it until i can get it loose again and it then goes into gear
whats going on with it.. please help me
Old Jan 31, 2006 | 02:38 PM
ShadyBAB's Avatar
Default Re: transmission problem..help please (96CivicTN)
Sounds like you need to change your tranny fluid, or may be a Syncro problem
Old Jan 31, 2006 | 03:58 PM
96CivicTN's Avatar
its a 5spd
Old Jan 31, 2006 | 05:45 PM
ShadyBAB's Avatar
What does that have to do with it?
Old Jan 31, 2006 | 05:46 PM
Arawn_Wilsawn's Avatar
sounds like your clutch is starting to slip
Old Jan 31, 2006 | 05:53 PM
robbieshonda's Avatar
Default Re: transmission problem..help please (Arawn_Wilsawn)
sounds like syncro's to me. drop your trans. atake the case aprt and look inside or drain your trans fluid. put a magnet in the fluid see how much metal flake is in it some is normal alot is bad. and look for brass in the fluid alot of that means youve been grinding on the dogbones.
Nate13
24
Jul 9, 2010 08:19 AM
goku335
Honda Civic (2006 - 2015)
Jun 8, 2009 12:39 AM
sportinjected
Jul 9, 2008 08:21 PM
SR20S13
Jun 18, 2007 02:32 PM
elevatethis
41
Nov 24, 2003 12:02 AM
