Randon Misfire, CEL 71 & 73
Old Jan 31, 2006 | 02:30 PM
Punker1234's Avatar
Default Random Misfire, CEL 71 & 73
Heya. I recently fixed some stuff on my car and everything was good. No CEL for a day and bam I throw 71 and 73. I replaced Spark Plugs, Plug Wires, Rotor and Cap. Gonna try switching the injectors on a day where I can drive long enough to throw the code, but anything else I should check out before I take it in to see if valves are okay?
Old Jan 31, 2006 | 04:08 PM
Punker1234's Avatar
Default Re: Random Misfire, CEL 71 & 73 (Punker1234)
bump for any help
Old Jan 31, 2006 | 05:03 PM
hondapwr's Avatar
You're on the right track. Swap the injectors and see if the problem follow them. (Which means you need to remember which injectors went where..)
Old Jan 31, 2006 | 05:25 PM
Ross 2.0's Avatar
In a Junkyard near you.
Also valve adjustment.
Old Jan 31, 2006 | 06:37 PM
hondapwr's Avatar
Default Re: (MooGoCow3)
Valve clearance out of spec causes misfires? Explanation?
Old Jan 31, 2006 | 07:43 PM
Jorsher's Avatar
yeah i had a random misfire in 2 cylinders once, although it hasn't happened again
Old Jan 31, 2006 | 11:29 PM
Punker1234's Avatar
Default Re: (Jorsher)
well before I relpace everything it took maybe 15 miles for the cels to trigger. I've now driven like 40 miles after replacing the stuff and no light, BUT i can still feel it misfire from the exhuast and the idle is just rough. not fluctuating idle but rough, im sure you guys know. tomorrow im gonna check my injectors swap them around. I do have aftermarket fuel pump on there but my pressure reads liek 38 or something so it seems good. Valves i'll have to get. I hate keep dumping money into a stock civic blah. another 70 bucks for an adjustment
PS: THANKS FOR YOUR HELP IN ADVANCE. It's nice to have help when u REALLY need it. Im on the verge of going insane after replacing xxx # amount of parts.
Old Feb 1, 2006 | 05:17 AM
hondapwr's Avatar
Default Re: (Punker1234)
Check the plug color too. Are they White? Black and sooty? Tannish?
I wouldn't waste money on a valve clearance adjustement yet, until moogocow explains why.
Old Feb 1, 2006 | 12:08 PM
Punker1234's Avatar
Default Re: (hondapwr)
what plug color? nah i also read valves can do it as well. possibly they loose or one is bent can sometimes cause a misfire, or even carbon buildup supposely. but thats one of the last things I wanna do. we'll see, i gotta try and get this cel light to come on!
Old Feb 1, 2006 | 05:10 PM
Punker1234's Avatar
yea what the hell. i replaced cap rotor, plugs and wires and the CEL has yet to come on, and i KNOW it's misfiring. it's a rough idle and the exhuast is not smooth at all. Prolly driven 60 miles now and nothing. but i have vtec been awhile
Old Feb 2, 2006 | 10:24 AM
Punker1234's Avatar
WTFFF just threw
90 Evaporative Emission Control System leak detected in the fuel tank area
now im scared my car si going to blow up haha. Cel 71 and 73 didn't show, now i got this! Can't be my gas cap, cus it just came up on the freeway, and after all these problems would it be related to my misfiring in any way? i also checked the lines evap(betwene injectors) and everything seems mfine. no rips in the line to the canister and to the manifold
Modified by Punker1234 at 11:42 AM 2/2/2006
Modified by Punker1234 at 1:04 PM 2/2/2006
Old Feb 2, 2006 | 12:22 PM
Punker1234's Avatar
up again
Old Feb 2, 2006 | 02:45 PM
Punker1234's Avatar
anyone? i need a smog in 6 days
Old Feb 2, 2006 | 05:03 PM
Punker1234's Avatar
come on
Old Feb 2, 2006 | 06:25 PM
Punker1234's Avatar
hmmm guess im gonna take it to honda ot diagnos
Old Feb 2, 2006 | 06:29 PM
Heylookits shawn's Avatar
are the sparkplug wires in the right order?
and code 90 is usually when your gascap is off
Old Feb 2, 2006 | 06:59 PM
Punker1234's Avatar
Default Re: Random Misfire, CEL 71 & 73 (Heylookits shawn)
gas cap is not off, plugs are fine. the car runs fine, it just misfires
Old Feb 2, 2006 | 07:49 PM
Punker1234's Avatar
last effort
Old Feb 6, 2006 | 12:49 PM
TYPErCRX's Avatar
i had the same problem with my 99 civic i tryed everything so i finally said this has to be mechanical sure enough it was i have code 73 and 74. cyl #3 had a exhaust valve with a hole right though it do to improper seating againtiest the head and cyl.#4 had a bent rod.! if i were you i would check the compression of each cyl. they all should be between 150 to 200psi. yea i know it sounds like alot for a sohc but thats the specs. i check that before anything else! good luck with it let me know what happen's
Old Feb 6, 2006 | 03:49 PM
Punker1234's Avatar
Default Re: Random Misfire, CEL 71 & 73 (TYPErCRX)
compressio si 180 across the board
Old Feb 8, 2006 | 02:31 AM
TYPErCRX's Avatar
have you tryed a main relay i burn out 2 since i started driving hondas or maybe a hole new dizzy? let me know what you have done so far up to this point
Old Feb 8, 2006 | 04:40 PM
Punker1234's Avatar
yea im gonna take it into honda, it's prolyl cheaper to have them tell me whats wrong then relpace everything little by little
Old Feb 8, 2006 | 09:12 PM
Punker1234's Avatar
could a cat cause misfiring? even though the misfiring seems to be in the same cylinders... plz anyone
Old Feb 9, 2006 | 03:31 AM
TYPErCRX's Avatar
i think the cat could cause it with to much back pressure but at the same time i think it would be all cyls anyway think so....
Old Feb 10, 2006 | 06:00 PM
Punker1234's Avatar
SWEET misfiring on 1 2 3 4 cylinders haha. beautiful. Gonna take it in, im guessing it's some lame eletrical issue. Glad i got 750 back from our lovely government Ill let evyerone know whats the issue if anyone cares for future reference
adamrich33
Sep 17, 2013 09:13 AM
da9blk1
Jun 5, 2012 07:50 PM
ftrms
May 1, 2010 11:00 AM
GraveS2000
Honda S2000
Apr 30, 2007 04:55 PM
typer rick
Apr 13, 2004 07:58 AM
