eg dx to power windows
there are two ways to do the wires. 1. is to get just the door wires ( power window, lock, and mirror harness) and then clip the head off the end which runs along the floor ( you will need both pass. and drivers side plug head ), connect the wires with addtitional wires and soder. 2. get the inside floor harness and door harness. this is 100% plug and play. You will need to get this floor harness from a junkyard and is a PIA to remove, but makes the swap easy. I did the swap and now I have keyless entry and don't have to lean to open the passenger side window or lock
. I have the power door panels in black for the swap. let me know if you are interested in them.
