EG POWER WINDOWS
Old Aug 4, 2005 | 09:11 PM
Dc2Trini's Avatar
Default EG POWER WINDOWS
Ok i want to know if eg6 has connections for the motor and the power windows switchs or do you have to the wires for it. thanks
Old Aug 5, 2005 | 08:59 AM
DM95eg's Avatar
Default Re: EG POWER WINDOWS (youngtrini2)
bump i would like to know this too
Old Aug 5, 2005 | 09:14 AM
fcm's Avatar
fcm
Old Fart
I am not sure, but when running speaker wires into doors of Honda/Acuras that do not have power windows or power door locks, I have found, the door side plugs do not have any extra wiring in them other then what is being used, but on some models the car side plug has a number of wires that the door side plug does not.
This would make sense if power windows and door locks are an option, I mean why would you have more then one main harness, just like the oem alarms, even if the car didn't come with the alarm, if it was an option the plug is there. 94
Old Aug 5, 2005 | 09:25 AM
DM95eg's Avatar
Default Re: EG POWER WINDOWS (fcm)
thanks alot man im pullin my underdash apart today to see if it will work in my cx hatch
also check this site http://repo.jackmoves.com/albun42?page=1
Old Aug 5, 2005 | 10:29 PM
Dc2Trini's Avatar
Thanks
Old Aug 14, 2005 | 01:05 PM
DM95eg's Avatar
i want to keep this thread alive. That site is useful but a little confusing. can i use integra or 96 and up civic power window assembly? thanks
Old Aug 15, 2005 | 07:22 PM
DM95eg's Avatar
Default Re: EG POWER WINDOWS (DM95eg)
bump
Old Aug 16, 2005 | 06:37 AM
dognutz's Avatar
There are no additional wires or plug ends. This is not that hard.I just did this swap on my 92 si hatch. You will need door wires from an ex and the fuse panle connection wires at least. This is where you will need to check compatiblity from other years models. I know that integra's have the control for power mirrors on the door arm rest instead of in the dash. I can see this causing some problems. If you mean the motor I would say you need to make a trip to the Jyard to check compatiblity. If you want an easy install get the under dash wires that run from one side to the other. They are a pain to remove but make installation a snap. If you take this route it is strickly plug and play. I have door wires and fuse panel connections wires and black door panels for the upgrade. Let me know if you are interested.
integraracing91
Audio / Security / Video
Sep 11, 2006 11:01 PM
myronwong
Jul 19, 2006 10:46 PM
aquabob89
Jan 31, 2006 11:18 AM
DA808TWITCH
Oct 20, 2005 03:41 PM
