smoke comming out manifold
I tried to go to school this morning and the car wouldnt start. So I waited until later today to try to crank it. Nothing happend at all and then I finally turned on. Turned the car off and tried to crank it again and big cloud of smoke came out of my air filter. I opened the throttle body and saw smoke comming from there. Not sure what is wrong any suggestions?
Also the day before it turned on and while i was driving the car shut off. Pretty sure my grounds are ok since i checked them and my battery is reading 12.3 volts
From: On a island w/ only a bridge to leave it, U.S.A
Haha the same thing happend to me. My intake like *Coughed* and white smoke came out, did it smell like anitfreeze? Im not sure of an answer but I will like to hear one. bump.
Also I would suggest doing a leak down test, to check valve seals and piston rings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmz6eg1 »</TD></TR><TR><TD CLASS="quote">whatever it is it doesn't sound good</TD></TR></TABLE>
Jeeesh you're quite the ******* genious
Sounds like maybe you got alittle too much water sucked up through your intake.
Or one of your piston rings might be fried causing too much oil in a cylinder.
Good luck guys
Good luck guys
hey man I had the same problem, except it was in my gasket, just go to honda and get a new gasket be carefull when you take the screws out, mine broke in the middle and I had to get a freind to dril out new holes and crap.. anyways i got other probelms now..
1SickHb
17
Mar 8, 2004 01:43 AM
dustineck
Sep 8, 2003 05:50 PM
