92 LS SWAP INTO AN 88 DX HATCH
I have completed the swap my wiring harness was converted to obd1 by hasport, I have a boomslang jumper harness wired in, and an obd1 pr4 ecu. the engine is obd1 also, the engine cranks and wont start, the engine ran perfect before I did the swap, so no issues there, the fuel pump doesn't run and there isn't any spark either. I powered up the pump with a power probe and it runs if I supply the power and ground, but still no spark! I just can't figure out the no spark part? I need some help so if anyone has any comments of info i would greatly appreciate it! thanks
when my hatch wouldnt get spark after my swap is because my distributor was bad.try checking the distributor see if you have power to the wires to it. i got a new distributor was fine. i dont know anything about the fuel pump though. hope this helps.
so what? that made no sense, i believe it's wiring also but i repinned all of the wires that hasport told me too and wired everything correctly according to boomslangs diagrams and even called hasport to confirm that I wired it ok! I've got a buddy that works at honda who is goin to look at it for me tonight! but i am a lil bit iffy about the main relay but will need to check that too! thanks
hasport says that the wiring is different from their harness to the boomslang one something to do with the dizzy wiring hopefully i can figure it out if any one has info i am desperate i could probably hire some strippers or hoookers for someone at this point. definitely need more info thanks alot
russian_racer
28
Jul 20, 2003 01:17 PM
