camber kit question
i have a 91 si and im about to drop it 1.9 in the front and 1.8 in the back with h&r springs, my question is this: do i really need a camber kit? if so which brand should i get or does that not matter?
I dropped my integra only 1.75 in the front and needed a camber kit BAD. Do get an alignment first, and make sure you ask if the camber was off. if its out of the service limits, you will need a camber kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr »</TD></TR><TR><TD CLASS="quote">I dropped my integra only 1.75 in the front and needed a camber kit BAD. Do get an alignment first, and make sure you ask if the camber was off. if its out of the service limits, you will need a camber kit. </TD></TR></TABLE>
Did you have bent suspension pieces or what?
Dirty Octopus
28
Feb 20, 2010 05:47 AM
