ls engine mount brakcet studs need helpppppp!!!!!!!!
Old Jan 30, 2006 | 08:13 PM
bbrian's Avatar
Default ls engine mount brakcet studs need helpppppp!!!!!!!!
my ls motor only had one stud in the driver side mounting bracket i was wondering if it was hard to put on in it ,, thanks...
Old Jan 30, 2006 | 08:29 PM
VtecSyndrome's Avatar
Default Re: ls engine mount brakcet studs need helpppppp!!!!!!!! (bbrian)
Not quite sure I follow but if it it's broken then just drill it out and either re-tap it or just run a proper sized bolt through it and it will be fine. If you are thinking there should be 2 studs instead of one? The 88-91 EF and 90-93 DA all have 1 stud and you run a bolt through the other side anyway.
Old Jan 30, 2006 | 08:35 PM
bbrian's Avatar
Default Re: ls engine mount brakcet studs need helpppppp!!!!!!!! (VtecSyndrome)
o damn thanks man yeamine only has one i ,,, i was like damn this is gonna blow but thanks man
Old Jan 30, 2006 | 08:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbrian &raquo;</TD></TR><TR><TD CLASS="quote">o damn thanks man yeamine only has one i ,,, i was like damn this is gonna blow but thanks man</TD></TR></TABLE>
Cool, I figured that was what you were dealing with
ferio 95
Jun 7, 2004 11:31 AM
RSVTECDC4
Jul 16, 2003 04:22 PM
xEGxB18Cx
Jul 5, 2003 05:42 PM
216.226.142.95:27016
Jun 29, 2003 02:27 PM
89JDMcrx
Dec 17, 2002 08:48 PM
