Weird...fuel problem?
Old Jan 30, 2006 | 06:01 PM
trooper0641's Avatar
Default Weird...fuel problem?
The ecu wasn't blinking when I turn the key to the second "ON" position so somethings weird. I tested the fuel pump line (black/yellow) to see if it was getting any voltage. There was no voltage....I rigged a wire from the 10A fuse box to the fuel pump line...there is voltage and the fuel pump is priming but as I start the car...it wouldn't turn over. I thought it was the main relay...so I went out and got a new one...switched it and still no luck. I thought it might've been the main relay going back and not sending any signal to the ecu because the ecu wasn't blinking like before. Sounds like theres no fuel going through...I would've checked the fuel line to see if there was any fuel coming but I didn't have the tools on me and my car is stuck in the middle of no where close by to my house. Just got back from it...and its dark now so ill check tomorrow.
Old Jan 30, 2006 | 08:54 PM
Default Re: Weird...fuel problem? (trooper0641)
ttt
Old Jan 30, 2006 | 09:03 PM
ILUVMYEM1's Avatar
you might end up needing a fuel pump........
Old Jan 31, 2006 | 09:04 AM
Default Re: Weird...fuel problem? (ILUVMYEM1)
bump
Old Jan 31, 2006 | 10:33 AM
aquabob89's Avatar
* B A N N E D *
is your ecu fuse blown when you click the key to acc does it make the buzz nose so that you know your fuel pump is engaging check it its under the dash and is 10a
Old Feb 1, 2006 | 09:40 AM
23r23rwef23
krysted9354
20
Apr 8, 2009 03:32 PM
92hatchboi
11
Apr 24, 2007 07:59 AM
hedtrip
Feb 18, 2006 08:53 AM
trooper0641
Feb 1, 2006 09:40 AM
tilt
Nov 21, 2002 09:25 PM
