Weird...fuel problem?
The ecu wasn't blinking when I turn the key to the second "ON" position so somethings weird. I tested the fuel pump line (black/yellow) to see if it was getting any voltage. There was no voltage....I rigged a wire from the 10A fuse box to the fuel pump line...there is voltage and the fuel pump is priming but as I start the car...it wouldn't turn over. I thought it was the main relay...so I went out and got a new one...switched it and still no luck. I thought it might've been the main relay going back and not sending any signal to the ecu because the ecu wasn't blinking like before. Sounds like theres no fuel going through...I would've checked the fuel line to see if there was any fuel coming but I didn't have the tools on me and my car is stuck in the middle of no where close by to my house. Just got back from it...and its dark now so ill check tomorrow.
Re: Weird...fuel problem? (trooper0641)
is your ecu fuse blown when you click the key to acc does it make the buzz nose so that you know your fuel pump is engaging check it its under the dash and is 10a
krysted9354
20
04-08-2009 03:32 PM
trooper0641
02-01-2006 09:40 AM
