H22 EG Dead
Old Jan 30, 2006 | 04:46 PM
2000Pimpinex's Avatar
Default H22 EG Dead
Went to the store last night and everything was fine. Come out, try to start her up and nothing. It cranks fine but its not getting any spark. I already replaced the distributer button and was going to replace the cap but I couldn't find anyone who had an internal coil cap. Anyone have any other suggestions what it might be while I try to track down a cap??
Thanks
PS already checked for fuel. Its getting that.
Old Jan 31, 2006 | 05:25 AM
ThE PiMpiN Co's Avatar
Default Re: H22 EG Dead (2000Pimpinex)
What is a distributor button? Check your igniter, its in the distributor, its usually the thing that goes bad in the distributor.
Old Jan 31, 2006 | 05:42 AM
Default Re: H22 EG Dead (aRaBiAn RiCe)
As soon as you take the distributer cap off. Its the next thing you see. I call it a button.
Old Jan 31, 2006 | 05:46 AM
I dono? I think you're talking about the distributor rotor.
Old Jan 31, 2006 | 05:48 AM
Thats probably it. I'm picking up a 92-95 civic cap after work. I was told that it has an internal coil and would fit. If that don't solve the problem then I'll try something else.
kulrevon's Avatar
when you turn the ignition to the on position does the check engine light go on for 2 sec then go off?
also when you stopped the car did you have an problems with the tach bouncing or not working?
Old Jan 31, 2006 | 05:50 AM
Default Re: H22 EG Dead (kulrevon)
I didn't notice any problems when I stopped the car. It seemed to be running like it normally does. Not sure about the check engine light. Will check when I get off work in a few hours. I thought it always comes on though. Could be mistaken.
1badcrx
May 9, 2009 12:58 AM
2000Pimpinex
Jan 30, 2006 06:41 PM
eK9aT10pSi
Oct 1, 2005 08:27 AM
SI_niki
Jun 15, 2004 07:54 AM
dlric
Dec 13, 2001 03:55 AM
