Clutch went out (99sh)
Old Jan 30, 2006 | 02:54 PM
mcbasspro's Avatar
Default Clutch went out (99sh)
hey guys
today i went to drive my car to school
and it wouldnt go into any gears.
turned on fine but wouldnt go anywhere
i guess my clutch is blown
i found a place to do a clutch and labor for 380... thats a awsome deal right?
considering every other place i called said 700-900 dollars
anyone think this is a little shaddy?
anyone in San diego know of any place good?
Old Jan 30, 2006 | 03:00 PM
dekr510's Avatar
Default Re: Clutch went out (mcbasspro)
I just payed $582 to get mine replaced , so your getting a good deal. Every where I went wanted around $800, dealer wanted $1,200.
Old Jan 30, 2006 | 03:12 PM
hondabigblock's Avatar
Have you checked your master or slave cylinder sounds like you lost pressure clutches dont usually blow
Old Jan 30, 2006 | 03:27 PM
RJonathan's Avatar
A clutch can just go out anytime. like with mine I was driving down the road and it poped out of gear and when I try to go into gear it was hard as hell when I pull the tranny one of the spring on the disc had popped out.
Also check your tranny fluid I had this happen to a friend of mine he woke up one day and had to force his car into gear. When we did his clutch swap there wasnt any Tranny fluid in his tranny but his clutch was still fine. so we poor some Fluid in and put the tranny back and he was able to shift into gear but the tranny is still kind of messed up.
Old Jan 30, 2006 | 06:59 PM
mcbasspro's Avatar
I had a friend check it out.
there is very little pressure on the pedel when i go to shift gears
it is still shifting some what, but my friend said it was the master cylinder because it wasnt keeping the pressure in.
what should i expect to pay for that?
oh and the 380 i mentioned------ i called again cause it seemd odd-- they miss quoted me (F****'s)
yoluder's Avatar
is your pedal really soft? usually if you drove it the day before and won't go into gear the next day then you probably got a : leak; bad master cyl; slave cyl; low tranny fliud could also be due too cold weather. look under your car for clear or brown/black fluid.
Old Jan 30, 2006 | 07:10 PM
mcbasspro's Avatar
i just checked my car.
no leaks out of the car
but got a flash light and where the clutch pedel meets the
car there is a dark brown fluid leaking out every time i push it in.
thanks for the fast replies guys
Old Jan 30, 2006 | 07:17 PM
CivicSiDriver02's Avatar
Default Re: (mcbasspro)
Yep, you are going to need a master cylinder. I would replace the slave cylinder also.
Old Jan 30, 2006 | 07:18 PM
BB6racer's Avatar
time to replace the sylinder! its not that hard, just a time consuming kind of thing. helps if you have a friend when you bleed the system.
Old Jan 30, 2006 | 07:24 PM
mcbasspro's Avatar
U GUYS OWN > life
!!!!u saved me more money on my car then geico!!!!!!!
im gonna get that shizzz taken care of tomarrow..... does a mech usualy have that kind of thing lieing around or is it special order? mech specializes in Hondas/acuras
San Diego, on Mission Gorge RD- MR. Lee's Auto repair. Anyone know him? awsome work and great honest prices. a bit hard to understand though.
Old Jan 30, 2006 | 07:49 PM
SteveoBA8's Avatar
Misdiagnosis pwns, yes a dealership should have many mc's and slave's in stock.
Dc295kid
Dec 19, 2009 07:05 AM
02_Si_FTW
Jul 21, 2008 01:57 AM
boostede46
Jan 28, 2008 07:36 PM
BlackMagikSI
Mar 7, 2006 06:54 AM
rriicckk787
May 10, 2005 05:13 PM
