bearings for b series
no no honda has seven different "color codes", the color codes are comprised of letters and numbers, on the rods the letters stamped on the crank refer to the journal thickness of the crank. The number stamped on the rods refers to the big end bore of the rods.(the end that straddles the crank).
With the mains there are five letters stamped under the oil pan gasket of the block. those letters refer to the size of the journal for each main cap. The numbers on the crank refer to the size of the main journal.
Each color code differs by one tenth of a thousandth. from .0013 to .0020 for the rods. I'm not sure about the mains but judging by the question you should seek help and a helms manual. Goodluck.
yes i know i built many blocks before i just got a new one in and its a 90 b16a1 first gen and it doesn't list in the computer at the local parts store so i was thinking about a 97 delsol dohc b16 thats why i asked i know about the color codes and stuff but thanks man....
