WOW, I am impressed by the moroso oil catch can
Only after 2500km, it catched about 5 teaspoon or a little more of oil. It is really doing it's job.
BTW, am I catching too much or just about right?
after about 3-4 weeks of driving I got just under 1/4 litre off my b16a catch can installation. The first couple days I didn't get anything, but after some steady driving I got a decent amount. I've been told that b20's can get up to a full can in a month. The amount of oil I caught in the can was the exact amount my oil level dropped in that time period too , so almost all the oil consumption goes through the intake manifold, on my car anyways. Using the Moroso can also.
Joey
Joey
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
I loose 2 quarts of oil every 3000 miles, because I drive hard! With that being said. Where can I order a decent oil catch can, and how much?
how do you have your oil catch can installed?
1. from the valve cover to the intake
or
2. from the intake manifold to ??
or
my can sits between the stock breather tank and the intake manifold. Pipe the breather tank line to the Moroso can (using some Watts screw in parts), then I have a Ford Van pcv valve on the top of the can , and a line running from the pcv valve to the stock intake manifold barb. The stock Honda pcv valve is eliminated replaced by the one on the can. Running a can on off the valve cover breather is a waste of time as vast majority of oil vapours travel from the block to the intake manifold.
hth.
hth.
The purpose of the oil catch can is not to prevent burning oil. If your car burns oil, you will still burn oil with the oil catch can. It's just a better breathing system for the car.
The Cusco oil catch can was designed to be placed between the valve cover breather and the intake tube.
That being said, why do people put it in between the PCV and the intake manifold...I thought the whole point of the PCV was to inhibit oil from going to the intake manifold.
Will
On my Integra, it barely gets 1/4 cup of oil every oil change.. if that.
The B20 catch can usually fills to the brim by the time of an oil change.
For some reason the big bore motors create more.
Upload some pics of this catch can setup.
Larger picture: http://www.imagestation.com/picture/...5.jpg.orig.jpg
[Modified by BSQ, 7:51 PM 3/25/2002]
Larger image: http://www.imagestation.com/picture/...d.gif.orig.gif
[Modified by BSQ, 7:59 PM 3/25/2002]
I am going to eliminate the stock PCV valve and run an open atmosphere setup off of the back of the block. I figure it wont pollute any more than a test-pipe and I just put a high flow cat on my car.
"The B20 catch can usually fills to the brim by the time of an oil change."
I thought this was because the B20 blocks don't have the stock "separator box" that the VTEC blocks have. It has a drain-back feature in it. Correct?
EGgoJDM
Dec 1, 2009 12:05 PM
