Alternator belt
Old Jan 30, 2006 | 07:19 AM
H22a T13's Avatar
Default Alternator belt
I need to change it.
Should i buy it from honda or from a parts store.
If at a store what size is the belt?
For install do i just need to loosen the alt or do some other stuff
Old Jan 30, 2006 | 07:59 AM
ed_1's Avatar
Default Re: Alternator belt (H22a T13)
Just buy it off a parts store, loosen the alternator, put the new one in, and make sure everything is ligned up correctly otherwise you'll mess up your new belt. And check belt tension when done.
Old Feb 11, 2006 | 12:02 PM
wrx'n you's Avatar
Default Re: Alternator belt (ed_1)
im gotta do mine too..im getting mine from Honda though, im an OEM nut...lol
Old Feb 11, 2006 | 12:04 PM
SteveoBA8's Avatar
Default Re: Alternator belt (WILLFUTHEGREAT)
https://honda-tech.com/zerothread?id=1333261 pwned
Old Feb 11, 2006 | 11:41 PM
michael_t's Avatar
it is pretty hard to get the belt on because of the tight fit but try to get it on the altenator first after you loosen the top bolt on the altenator then get it on the pully as far as it will go then turn pully by hand and it will go on lke a bike chain
southernSCHEME
22
Jun 28, 2011 06:26 PM
jdm_speed
Engine Management and Tuning
Feb 18, 2009 01:01 AM
failed
Sep 4, 2005 05:59 AM
JMod
16
Jun 23, 2005 11:49 AM
519[H]Si
May 25, 2004 09:25 PM
