Car dies while driving!!!!
Old Mar 24, 2002 | 01:10 AM
The Brown Kid's Avatar
Default Car dies while driving!!!!
Sometimes, but not all the time, my car just dies while im driving. What are some possible problems????
Old Mar 24, 2002 | 01:35 AM
.MilanoRex's Avatar
Default Re: Car dies while driving!!!! (Iron Flag)
why is this a poll? LOL
Old Mar 24, 2002 | 05:53 AM
Ruby Civic's Avatar
Default Re: Car dies while driving!!!! (crXtreme)
could be electrical, but I know mine was the clutch combo was too tight........
Old Mar 24, 2002 | 06:29 AM
slash00R's Avatar
New User
Default Re: Car dies while driving!!!! (Ruby Civic)
battery or electrical .. if the battery is shot and can't hold a charge, it will pull too much current from the alternator and in turn cause the distributor to not get enough spark
Old Mar 26, 2002 | 03:34 PM
CRXRageD's Avatar
Dude, check your engine grounds. Also, check the ground inside the car around the fuse box. If you have a loose engine ground, all kinds of crazy **** will happen. It took me 2 weeks before I thought to check my grounds. it was the ground on the thermostat housing that was loose.
Old Mar 27, 2002 | 07:15 AM
Cryptopsy's Avatar
Make sure your battery terminal is not touching your metal air intake pipe. It will short out and burn a hole through the intake tube. Don't ask me how I know this... <--me
Old Mar 27, 2002 | 08:42 AM
gokooljapan's Avatar
check the IGNITOR!!
or if your battery is low or if you have to bump start it then it could be a bad alternator.....
but my friend had the same problem and it was the ignitor which is found in the distributor.....runs around 80$ at acura.....hth
Old Mar 28, 2002 | 08:32 PM
flat-blk-HB's Avatar
yeah check your grounds...i had the problem when i did my swap..the bolt on thermo. housing not tight enough....but maybe the iginter also..
Nick6
Aug 18, 2010 05:26 PM
fumpster
Dec 5, 2007 11:24 AM
t0ekn3e
11
Aug 17, 2006 08:25 PM
mt23vtecbb2
Nov 27, 2003 08:57 PM
brimy311
Mar 10, 2003 03:23 PM
