How did you guys run your OBD1 jumper harness?
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
poke a hole through that big rubber grommet that all the factory wires go in now..it above the ecu under the heater box. i use a piece of pipe and poke it trough the grommet. then feed the wires into the pipe and pull out the pipe out of the grommet leaving the wires . then you will have all your wire going through the same place the factory wires are in.
I shoved a coathanger, attached to a string, through the same spot. THen I just tied the string to the wires and pulled them through. It did take a while though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson »</TD></TR><TR><TD CLASS="quote">I shoved a coathanger, attached to a string, through the same spot. THen I just tied the string to the wires and pulled them through. It did take a while though.</TD></TR></TABLE>
This is what I was thinking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf »</TD></TR><TR><TD CLASS="quote">poke a hole through that big rubber grommet that all the factory wires go in now..it above the ecu under the heater box. i use a piece of pipe and poke it trough the grommet. then feed the wires into the pipe and pull out the pipe out of the grommet leaving the wires . then you will have all your wire going through the same place the factory wires are in.</TD></TR></TABLE>
That is how I did mine as well, the jumper fit through with ease and runs right by the factory harness for a really clean OEM look.
ok, thats how i ran mine to.. but the jumper harness connectors dont fit under my ecu cover? how do u guys have that set up? i finally got my carpet took around part of it, but if u look u can tstill see the jumpers sticking out the top carpet line. how do u hide them?
Canadian_EF
Jul 16, 2011 09:38 AM
therotaryrocket
Oct 12, 2008 06:45 PM
