205's fit our Stock Si wheels??
couldn't find this info specifically but i need new tires and i would very much like to move up to 205/40/14 on my stock Si Wheels, i dont think i've seen this but is it possible to fit a tire this profile on my stock Si sawblades...but most of all i want the wideness of the tire to be most important requirement...thanks..
also i just found these on tirerack.com will these fit my wheels?
http://www.tirerack.com/tires/...ace=0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede »</TD></TR><TR><TD CLASS="quote">I've used 195/60's before (Azenis) and they were pretty big for the rim, but worked very well.</TD></TR></TABLE>
yea i'm sporting the 195/40's rite now but i really wanna wid.en that too, so the 205's are a must..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d »</TD></TR><TR><TD CLASS="quote">
yea i'm sporting the 195/40's rite now but i really wanna wid.en that too, so the 205's are a must..</TD></TR></TABLE>
how is the ride on those. why are you running a 20" inch tire, if you dont mind me asking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey »</TD></TR><TR><TD CLASS="quote">how is the ride on those. why are you running a 20" inch tire, if you dont mind me asking?</TD></TR></TABLE>
the ride's good, but i feel like theres times i feel like they're slipping away..but thats also including my recently swapped b16...with the d16..they were perfect but maybe its just me with a little more power being pumped out from the b16..i feel like the 195's are JUST cutting it but i wanna be comfortable taking smaller risks on 205's..
by the way i'm riding on tein's, so suspension wise i'm pretty well off, just feel like i need wider tires!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d »</TD></TR><TR><TD CLASS="quote">couldn't find this info specifically but i need new tires and i would very much like to move up to 205/40/14 on my stock Si Wheels, i dont think i've seen this but is it possible to fit a tire this profile on my stock Si sawblades...but most of all i want the wideness of the tire to be most important requirement...thanks..
http://www.tirerack.com/tires/...ace=0 </TD></TR></TABLE>
First off, this tire is actually a 205/50/14. Secondly, it is a drag radial. And as such, these tires are not really designed for utimate handling on the street. If a 205 is really what you want, you are better off upgrading to a 15 inch rim and going with a 205/50/15. But if you REALLY want these tires, give the tire rack a call and ask them if they will fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">First off, this tire is actually a 205/50/14. Secondly, it is a drag radial. And as such, these tires are not really designed for utimate handling on the street. If a 205 is really what you want, you are better off upgrading to a 15 inch rim and going with a 205/50/15. But if you REALLY want these tires, give the tire rack a call and ask them if they will fit.</TD></TR></TABLE>
ok awesome yea, that helps somewhat..i really also wanna stay away from getting 15" wheels i wanna keep my stock alloy's and you bring up a good point on the drag radial's not designed for handling.....but i guess i'm calling on all 14" alloy's sporting the 205's by now i dont really care what kind they are i'm pretty much set on getting 205's on my 14" so...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrey320 »</TD></TR><TR><TD CLASS="quote">No, 205 will not fit a 14 inch rim</TD></TR></TABLE>
***...well that sucks...guess i'm gettin the rt215's then.....***..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey »</TD></TR><TR><TD CLASS="quote">what the width of the stock rims? if its 5.5" then a 205 will fit</TD></TR></TABLE>
yea ..does anyone know?
That sucks! I just put on 195 60 14 azenis on my stock 14 inch rims. I called like 3 shops and they all said that 205 will not fit my 14 inch rim.
Oh well, good to know for next time.
At least I got a killer deal on the azenis - $186 total for 4 tires (through a wholesaler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">im rocking 205's on my 14's right now.</TD></TR></TABLE>
wow yea..i pm'd you..but i'm sure evryone else would like to know what brand/which tires are you riding on..thanks mate..
I am confused on why you guys are so stuck on the idea of the widest tire possible. I guess I can understand this if you are going straight. But if you are trying to make the car handle better wouldn't a proper size handle than some oversize tire that buldge out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick »</TD></TR><TR><TD CLASS="quote">I am confused on why you guys are so stuck on the idea of the widest tire possible. I guess I can understand this if you are going straight. But if you are trying to make the car handle better wouldn't a proper size handle than some oversize tire that buldge out?</TD></TR></TABLE>
you know upon research i found the same result, throwing on a wider tire on a stock sized rim, will result in a bulge of the sidewalls, and in straight line thats not a problem but when handling is concerned they'll flex and work against the car's handling charecteristic...so i'm sticking to the 195's as they're fat enough...thanks...
NONKonformyst
Jan 11, 2003 08:08 AM
