WTT: H22 civic imagine engineering 4-1 race header for 4-2-1 oem manifold
i have an imagine engineering 4-1 race header in my H22 EK hybrid. huge primaries and collector. i have the original receipt for it. the ceramic finish was worthless on it, and it has a lot of surface rust. nothing that can't be sanded/blasted out and re-painted. this header is no-longer made and imagine engineering is no longer in business (as far as i know). at any rate, dyno claims were gains of 8-15whp depending on mods and tuning
on my daily driver i don't like the ground clearance on the header, i want to re-install A/C and P/S and i could use the $$
i need $250+ a mint JDM/USDM 4-2-1 OEM exhaust manifold. trades ONLY. i cannot have any down-time as this is my daily driver.
i live in SW MI zip 49024
Modified by DOHCvtecDX at 1:08 PM 8/21/2006
dyno test
https://honda-tech.com/zerothread?id=678809
search the archives, there some good info about the header out there
here's an actual original pic of it
https://honda-tech.com/zerothread?id=658365
Modified by DOHCvtecDX at 2:42 PM 1/29/2006
Modified by DOHCvtecDX at 2:43 PM 1/29/2006
I've got a stock JDM exaust mani, with heat shield n all. The flange that connects to the cat was cut off though... I still have the flange and cat also. It would take nothing to weld back up.
LMK if you are interested!
bump this old **** up
looking again
any stock H22 header WITH A HEAT SHIELD and downpipe will work.
looking again
GAccord
17
Sep 15, 2004 10:17 AM
